Static crackle/distortion
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
jonnyfive
Post by jonnyfive » Sun Aug 16, 2009 9:44 am
I'm recording Vinyl mixes through the master 2 output on a vestax mixer, and berhinger device to my mac. Even keeping the master level, and the gain very low, I'm getting a static crackle/distortion which seems to be directly linked to the volume. I've tried keeping the mic level down too but it doesn't seem to help much. I'm no technical genius and was wondering if anyone might have any tips?
Re: Static crackle/distortion
Post by kozikowski » Sun Aug 16, 2009 7:03 pm
<<<vestax mixer>>>
Model numbers are good. Also good is a detailed explanation on what the turntable is and how you have it connected.
<<<berhinger device to my mac.>>>
Why are you using the Behringer and which one is it?
jonnyfive
Post by jonnyfive » Mon Aug 17, 2009 8:50 pm
ok,
Technics 1210 > vestax VMC 004XL > Behringer u-control UCA202 > macbook
Hope this helps!
Jon
Post by kozikowski » Mon Aug 17, 2009 11:36 pm
What happens if you take one of the outputs of the mixer and go straight into the Line-In of the Mac with one of these?
http://www.radioshack.com/product/index ... Id=2102972
Switch the Mac Preferences to Line-In and watch the Apple blue patch volume meter when you play the music. Do you get bouncing lights somewhere in the upper third? You may need to adjust the Mac preference volume.
