Does anyone know which version of the ID3 metadata tags is used in the beta version of audacity. The dialogue box to choose the version number does not seem to be in the new version and I require ID3v1. How would I select this?
many thanks
ID3 version in Audacity Beta
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
stephen_77
waxcylinder
Re: ID3 version in Audacity Beta
IIRC it is ID3v2 - and you are right AFAIK it is not resettable in 1.3.x
You may need to find an external converter package which will give you more control over settings than the Audacity plugin - export from Audacity as WAVs and pass these through the converter. You should be able to find a free one on t'interweb.
- Quality Assurance
