Can anyone test "Plot Spectrum" in Audacity 1.3.8
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Post by steve » Mon Jul 27, 2009 11:47 am
I notice that "Plot Spectrum" in Audacity 1.3.8 produces a different output from earlier versions.
I'm using Audacity 1.3.8 on Linux, but I expect this to be the same on all platforms.
Here is an example of the type of thing:
In any version of Audacity 1.3.x
1) Generate 20 seconds of silence at 32 bit 44.1kHz
2) Set Audacity Preferences to "High Quality Conversion" > "Shaped dither" (in "Quality" tab)
3) Export as 16 bit WAV
4) Import this file into Audacity (it will have had shaped dither applied due to the bit rate being dropped from 32bit to 16 bit).
In Audacity 1.3.8 I get this and it appears that no dither has been applied:
Silence downsampled from 32bit to 16bit in Audacity 1.3.8
When using Audacity 1.3.7 the characteristic high frequency noise of the shaped dither is clearly evident:
Silence downsampled from 32bit to 16bit in Audacity 1.3.7
Can anyone test this in other software?
(Koz, do you have your Cool Edit Pro installed anywhere?)
Re: Can anyone test "Plot Spectrum" in Audacity 1.3.8
Post by Gale Andrews » Mon Jul 27, 2009 5:27 pm
The spectrum is off the scale. Reduce the Meter/Waveform dB Range on the interface tab of Preferences
Post by steve » Mon Jul 27, 2009 5:40 pm
Gale Andrews wrote:The spectrum is off the scale. Reduce the Meter/Waveform dB Range on the interface tab of Preferences
But why is it off scale in Audacity 1.3.8 and on scale in previous versions of Audacity?
Both images below show a range of -90dB to -80dB, but in Audacity 1.3.8 the peak is at around -110dB rather than -80dB !
Post by Gale Andrews » Mon Jul 27, 2009 6:26 pm
This was discussed on -devel list. I've commented here:
http://n2.nabble.com/Plot-Spectrum-in-1 ... 35287.html
and the thread where it was discussed in detail is here:
http://n2.nabble.com/Re%3A-Question-abo ... 92212.html
From user's point of view (if coming from previous versions) I do think the new scaling is confusing, and needs a full explanation in the manual. I've made my concerns clear on -devel list.
Post by steve » Mon Jul 27, 2009 11:16 pm
Thanks Gale,
I've not yet read the "Numerical Recipes in C" - can't open it in Evince, and don't currently have Acrobat installed - also probably a bit heavy for bedtime reading - but the "bins" explanation worked for me. I look forward to reading the full explanation in the manual.
