Hello,
I've been using Audacity (in Ubuntu) for years--love it. Got most of it figured out, with a little help.
I make a three-hour streaming audio recording once a week, most of which I subsequently edit out. I notice that, each time I open Audacity, I have the option of recovering unsaved files. My question is, where are these recoverable files stored (in Ubuntu 8.04)? Can't find them in tmp files; I don't have a lot of memory and want to make sure they aren't accumulating unseen.
Thanks,
mike
From Where Are Projects Recovered?
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: From Where Are Projects Recovered?
If the project has not been saved, Audacity puts the data and temporary files in the default temporary file directory.
I think that the Ubuntu build of Audacity puts the temporary files in:
/home/user name/.audacity/
You can check by opening Audacity and looking in:
Edit menu > Preferences > Directories
(you can also change the default location).
After a project has been saved, the temporary files are put in the project data folder.
Steve, thanks a million--that is correct. I did find several hundred MBs of unnecessary data there. Much appreciated.stevethefiddle wrote:If the project has not been saved, Audacity puts the data and temporary files in the default temporary file directory.
mike
