editing very short section
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
I occasionally need to edit out a very short section of a file less than two (2) minutes is ther a way to either expand the width of the display ?
waxcylinder
Re: editing very short section
The zoom in amd zoom out tools are probably what you need - the magnifying glass icons
If you have a wheel mouse, then you can use Ctrl+wheel to zoom in/out.
