Hello,
Is there a remote control or similar external device available for Audacity? I'm looking for something like the ADS Tech Red Rover - http://www.usb-ware.com/ads-redrover.htm (which can remotely control Adobe Audition). Any ideas?
Thanks!
Remote control for Audacity?
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: Remote control for Audacity?
You can use a standard wireless keyboard.
Nearly all of Audacities functions can be done from the keyboard, and "hot keys" are configurable to suit any specific requirements you have.
I do not think that the Red Rover is made any more (obsolete product), but wireless keyboards are easily available for as little as $10. (paying a little more than this will probably get you a better keyboard).
