Waveform not centred
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Melvyn
Post by Melvyn » Tue Jun 10, 2008 2:41 pm
Hi,
I have Ubuntu Hardy Heron and Audacity 1.3.4.
I'm recording my vinyl record to copy them onto CDs. Today I noticed something that had never happened before: Normally waveforms are centred on the zero line of the dB scale. Well, now, although the right channel is centred, the left one is slightly above the zero line. How does this impact on the sound quality? And how do you fix it (i.e., lower the waveform so it "huggs" the 0 dB line?
Re: Waveform not centred
Post by Gale Andrews » Tue Jun 10, 2008 7:14 pm
Melvyn wrote:Hi,
It's known as DC offset. It can cause inaudible low level distortion (which becomes audible when filters/effects are applied or if the sound is compressed, for example in MP3 export). It can also cause audible clicks at start and end when played back (even without editing). Fix it by
* clicking on the Track Panel by the mute/solo buttons > Split Stereo Track
* click on the Track Panel of the left channel then Effect > Normalize and check the Remove DC Offset box > OK.
Look into fixing the sound device you are recording into/pre-amplifier/recording device you are using as appropriate.
Melvyn
Post by Melvyn » Wed Jun 11, 2008 11:29 am
Many thanks Gale. That solved it.
Melvyn
