Fade in/out from 100% to specific volume
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
JorgeBurgos
Hi, I am trying to fade out a portion of a track from 100% volume to a specific volume (e.g. 20%)... not just zero volume. I can't work out how to do this. Is there any way?
waxcylinder
Re: Fade in/out from 100% to specific volume
Try using the Envelope Tool - click on the tool icon with the two pointing together triangles, white dot at the centre blue line going through it.
This lets you set an amplification envelope by setting and dragging the little white dots, shaping the blue lines.
