(VERY) Good news is, after over a year trying to get sound input from my spdif input... on my MiaMidi snd card thru Ubuntu (Windows XP works fine), Audacity works, i.e., I can input digital sound (I think I have a problem w/Jack, etc.). But now it only records for 0.6 sec... I found some other people had similar problem/s, & the reply to them was "Look in "Help > About Audacity" - you should be using Audacity 1.3.7 not 1.2.x." Problem here, I am using Audacity 1.3.7. So what now? (I installed it yesterday, 7.20.09, & it did work then). Also, when I record, it does not use the track I set up, but creates a new one... is there something I can do to change this?
Thanks much.
Henry
Recording stops 0.6 sec Audacity 1.3.7 on Ubuntu 9.04
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Henry Heron
waxcylinder
Re: Recording stops 0.6 sec Audacity 1.3.7 on Ubuntu 9.04
In 1.3 to append to the end of your existing track just hit CTRL+R or CTRL+Record
Henry Heron
Hi WC,
Thanks!
I got the record to work... for desired duration, evidently I had the default parameter control button set to "end," (at the bottom of the window,) which I changed to "length," & that seemed to do the trick. It was apparently too obvious for me,
HH
Thanks!
HH
Henry,
I am having the exact problem with Audacity in ubuntu. Unfortunately, the selection of "length" over "end" is not working.
Does anyone have a solution they might suggest?
FYI -- I am using Audacity v1.3.7 (Unicode), and ubuntu v9.04
I found that reducing the recording sample rate fixed this problem for me. Mine was only recording about 0.4 sec though.
