itunes won't import aiff
This section is now closed
lucky13
Post by lucky13 » Thu May 07, 2009 6:42 pm
my itunes 8.1.1. on my 10.4.11 mac won't import aiff files from audacity. mp3's are fine but when attempting to import aiff, the plus sign in the green dot hangs for a few seconds then disappears.
Re: itunes won't import aiff
Post by kozikowski » Fri May 08, 2009 12:16 am
When you Export As AIFF, make sure you're not exporting 32-bit floating, the Audacity Default.
Sometimes downstream applications and tools don't like or understand 32-bit floating. Open the AIFF in QuickTime and Get INFO.
