Closed unexpectedly!!!
This section is now closed
Missy
Post by Missy » Thu Apr 23, 2009 11:36 pm
I recorded an interview and when I went to save it, the program closed. When I restarted it, it said that I could recover the files MANUALLY. But I do not know how to do that! Please help! :|
Re: Closed unexpectedly!!!
Post by kozikowski » Fri Apr 24, 2009 9:12 pm
This happened enough times that they wrote pretty good disaster recovery tools.
Crash Recovery
http://audacityteam.org/wiki/index.php? ... shRecovery
Post by kozikowski » Fri Apr 24, 2009 9:26 pm
Do you have any idea why Audacity stopped?
If you use Tiger or Leopard, you can use the drive management tools to make sure everything is OK.
Go > Utilities > Disk Utility > Select your drive.
The numbers at the bottom will tell you how full your drive is getting. Never let a production drive get over 90% full.
Verify. Repair Permissions. Close Disk Utility.
Do you run MacJanitor? That's the last housekeeping thing we have to do. Let's see how far you get up until now.
