Audacity crashes when vst enabler is present OS X
This section is now closed
rockness
Post by rockness » Mon Apr 13, 2009 4:08 am
I am using an OS X machine, a G5 desktop from a few years ago. When I place the vst enabler in the plug ins folder Audacity will no longer boot up. It crashes on start up. I have tried various builds of Audacity as well as removing all plug ins from the folder and just having the enabler. nothing works. Any ideas?? I miss my favorite reverb :(
Re: Audacity crashes when vst enabler is present OS X
Post by kozikowski » Mon Apr 13, 2009 5:46 am
This can happen if you have other audio software packages on your machine. This is someone else having the same problems.
http://audacityteam.org/forum/viewtopic ... ler#p28391
rockness
Post by rockness » Mon Apr 13, 2009 9:51 pm
i deleted the cfg file as per that response and still nothing. what else can i do? here is my log file from a typical crash that just occurred after i both deleted the cfg file and removed all plug ins from applicable folders:
Code: Select all
"Date/Time:      2009-04-13 17:49:48.412 -0400
OS Version:     10.4.11 (Build 8S165)
Report Version: 4
Command: Audacity
Path:    /Applications/audacity3/Audacity.app/Contents/MacOS/Audacity
Parent:  WindowServer [63]
Version: 1.3.7.1 (1.3.7.1)
PID:    218
Thread: 0
Exception:  EXC_BAD_INSTRUCTION (0x0002)
Code[0]:    0x00000002
Code[1]:    0x06141a1c
Thread 0 Crashed:
0   <<00000000>> 	0x06141a1c 0 + 101980700
1   com.apple.CoreFoundation  	0x907decfc __CFRunLoopRun + 1680
2   com.apple.CoreFoundation  	0x907de2b0 CFRunLoopRunSpecific + 268
3   com.apple.HIToolbox       	0x932acb20 RunCurrentEventLoopInMode + 264
4   com.apple.HIToolbox       	0x932ac12c ReceiveNextEventCommon + 244
5   com.apple.HIToolbox       	0x933b1160 ReceiveNextEventInMode + 72
6   net.sourceforge.audacity  	0x00310284 wxDropSourceBase::~wxDropSourceBase [in-charge]() + 196
7   net.sourceforge.audacity  	0x003b0248 wxDisplayModule::~wxDisplayModule [in-charge]() + 440
8   net.sourceforge.audacity  	0x00383c2c wxANIDecoder::Clone() const + 1004
9   net.sourceforge.audacity  	0x00480854 wxHashTable::~wxHashTable [in-charge]() + 3124
10  net.sourceforge.audacity  	0x00003834 0x1000 + 10292
11  net.sourceforge.audacity  	0x0000274c 0x1000 + 5964
12  net.sourceforge.audacity  	0x00002450 0x1000 + 5200
Thread 1:
0   libSystem.B.dylib         	0x9000af48 mach_msg_trap + 8
1   libSystem.B.dylib         	0x9000ae9c mach_msg + 60
2   com.apple.CoreFoundation  	0x907de9ac __CFRunLoopRun + 832
3   com.apple.CoreFoundation  	0x907de2b0 CFRunLoopRunSpecific + 268
4   com.apple.CoreFoundation  	0x907ed710 CFRunLoopRun + 52
5   com.apple.DVCPROHDMuxer   	0x059382bc AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 396
6   libSystem.B.dylib         	0x9002b908 _pthread_body + 96
Thread 2:
4   com.apple.audio.CoreAudio 	0x91459524 HALRunLoop::OwnThread(void*) + 264
5   com.apple.audio.CoreAudio 	0x914592c4 CAPThread::Entry(CAPThread*) + 96
Thread 3:
0   libSystem.B.dylib         	0x90040df8 mach_wait_until + 8
1   libSystem.B.dylib         	0x90040bc4 nanosleep + 388
2   net.sourceforge.audacity  	0x0000fe38 AudioThread::callback(void*) + 124
3   libSystem.B.dylib         	0x9002b908 _pthread_body + 96
Thread 0 crashed with PPC Thread State 64:
  srr0: 0x0000000006141a1c srr1: 0x100000000208d030                        vrsave: 0x0000000000000000
    cr: 0x24028282          xer: 0x0000000020000000   lr: 0x00000000907f2384  ctr: 0x0000000006141a1c
    r0: 0x00000000907f2370   r1: 0x00000000bffff3c0   r2: 0x0000000000002588   r3: 0x0000000005c388c0
    r4: 0x0000000006159000   r5: 0x0000000005c388c0   r6: 0xffffffffffffffff   r7: 0x0000000006ad2850
    r8: 0xffffffff5e4e3e2c   r9: 0x0000000000000000  r10: 0x0000000000000001  r11: 0x00000000a07bc2d8
   r12: 0x0000000006141a1c  r13: 0x0000000000000000  r14: 0x0000000000000001  r15: 0x0000000000000000
   r16: 0x0000000000000000  r17: 0x0000000000000000  r18: 0x0000000000000000  r19: 0x0000000000000000
   r20: 0x0000000000000000  r21: 0x0000000000000000  r22: 0x0000000000e1e968  r23: 0x0000000000e1e960
   r24: 0x0000000000e1e870  r25: 0x0000000000e1e968  r26: 0x0000000000000001  r27: 0x0000000000000051
   r28: 0x00000000fbe8f5b9  r29: 0x0000000005c388c8  r30: 0x0000000005c388c0  r31: 0x00000000907f22d4
Binary Images Description:
    0x1000 -   0x92bfff net.sourceforge.audacity 1.3.7.1	/Applications/audacity3/Audacity.app/Contents/MacOS/Audacity
  0xbf1000 -   0xbf3fff com.apple.textencoding.unicode 2.0	/System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
  0xfd4000 -   0xfdbfff com.unsanity.smartcrashreports Smart Crash Reports version 1.2.1 (1.2.1)	/Users/Jno/Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
 0x1e11000 -  0x1e1afff com.apple.LiveType.component 1.2	/Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
 0x1e26000 -  0x1e8afff com.DivXInc.DivXDecoder 6.6.0	/Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
 0x1fa0000 -  0x1fc7fff com.digidesign.digidesign.DigiCoreAudioPlugIn 7.3 (7.3f117)	/Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio
 0x584b000 -  0x58d4fff com.apple.DVCPROHDAudio 1.0	/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
 0x5921000 -  0x59b3fff com.apple.DVCPROHDMuxer 1.0	/Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
 0x5a22000 -  0x5a23fff com.apple.aoa.halplugin 2.5.6 (2.5.6b5)	/System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
 0x5a26000 -  0x5b23fff com.apple.audio.units.Components 1.4.7	/System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
 0x5b46000 -  0x5b46fff alias_1407.so 	/Library/Audio/Plug-Ins/LADSPA/alias_1407.so
 0x5b4a000 -  0x5b4bfff am_pitchshift_1433.so 	/Library/Audio/Plug-Ins/LADSPA/am_pitchshift_1433.so
 0x5b5e000 -  0x5b5efff amp_1181.so 	/Library/Audio/Plug-Ins/LADSPA/amp_1181.so
 0x5b70000 -  0x5b70fff comb_1190.so 	/Library/Audio/Plug-Ins/LADSPA/comb_1190.so
 0x5b7a000 -  0x5b7cfff analogue_osc_1416.so 	/Library/Audio/Plug-Ins/LADSPA/analogue_osc_1416.so
 0x5bba000 -  0x5bbdfff allpass_1895.so 	/Library/Audio/Plug-Ins/LADSPA/allpass_1895.so
 0x5bca000 -  0x5bcbfff bode_shifter_1431.so 	/Library/Audio/Plug-Ins/LADSPA/bode_shifter_1431.so
 0x5bed000 -  0x5beffff bandpass_a_iir_1893.so 	/Library/Audio/Plug-Ins/LADSPA/bandpass_a_iir_1893.so
 0x5bf5000 -  0x5bf7fff bandpass_iir_1892.so 	/Library/Audio/Plug-Ins/LADSPA/bandpass_iir_1892.so
 0x5d19000 -  0x5d1afff bode_shifter_cv_1432.so 	/Library/Audio/Plug-Ins/LADSPA/bode_shifter_cv_1432.so
 0x5d1f000 -  0x5d22fff butterworth_1902.so 	/Library/Audio/Plug-Ins/LADSPA/butterworth_1902.so
 0x5d2b000 -  0x5d2bfff const_1909.so 	/Library/Audio/Plug-Ins/LADSPA/const_1909.so
 0x5d59000 -  0x5d5afff chebstortion_1430.so 	/Library/Audio/Plug-Ins/LADSPA/chebstortion_1430.so
 0x5d5f000 -  0x5d62fff comb_1887.so 	/Library/Audio/Plug-Ins/LADSPA/comb_1887.so
 0x5d6e000 -  0x5d6efff comb_splitter_1411.so 	/Library/Audio/Plug-Ins/LADSPA/comb_splitter_1411.so
 0x5d73000 -  0x5d73fff crossover_dist_1404.so 	/Library/Audio/Plug-Ins/LADSPA/crossover_dist_1404.so
 0x5d95000 -  0x5d95fff dc_remove_1207.so 	/Library/Audio/Plug-Ins/LADSPA/dc_remove_1207.so
 0x5d99000 -  0x5d9afff decay_1886.so 	/Library/Audio/Plug-Ins/LADSPA/decay_1886.so
 0x5d9f000 -  0x5da0fff decimator_1202.so 	/Library/Audio/Plug-Ins/LADSPA/decimator_1202.so
 0x5da4000 -  0x5da5fff declip_1195.so 	/Library/Audio/Plug-Ins/LADSPA/declip_1195.so
 0x5da9000 -  0x5dabfff delay_1898.so 	/Library/Audio/Plug-Ins/LADSPA/delay_1898.so
 0x5db5000 -  0x5db7fff delayorama_1402.so 	/Library/Audio/Plug-Ins/LADSPA/delayorama_1402.so
 0x5dbe000 -  0x5dbffff diode_1185.so 	/Library/Audio/Plug-Ins/LADSPA/diode_1185.so
 0x5dc3000 -  0x5dc4fff divider_1186.so 	/Library/Audio/Plug-Ins/LADSPA/divider_1186.so
 0x5dc9000 -  0x5dcbfff dj_eq_1901.so 	/Library/Audio/Plug-Ins/LADSPA/dj_eq_1901.so
 0x5dd3000 -  0x5dd4fff dj_flanger_1438.so 	/Library/Audio/Plug-Ins/LADSPA/dj_flanger_1438.so
 0x5dd9000 -  0x5ddbfff dyson_compress_1403.so 	/Library/Audio/Plug-Ins/LADSPA/dyson_compress_1403.so
 0x5de2000 -  0x5de3fff fad_delay_1192.so 	/Library/Audio/Plug-Ins/LADSPA/fad_delay_1192.so
 0x5de8000 -  0x5de9fff fast_lookahead_limiter_1913.so 	/Library/Audio/Plug-Ins/LADSPA/fast_lookahead_limiter_1913.so
 0x5def000 -  0x5df0fff flanger_1191.so 	/Library/Audio/Plug-Ins/LADSPA/flanger_1191.so
 0x5df6000 -  0x5df8fff fm_osc_1415.so 	/Library/Audio/Plug-Ins/LADSPA/fm_osc_1415.so
 0x5dff000 -  0x5dfffff foldover_1213.so 	/Library/Audio/Plug-Ins/LADSPA/foldover_1213.so
 0x5e03000 -  0x5e03fff foverdrive_1196.so 	/Library/Audio/Plug-Ins/LADSPA/foverdrive_1196.so
 0x5e07000 -  0x5e08fff freq_tracker_1418.so 	/Library/Audio/Plug-Ins/LADSPA/freq_tracker_1418.so
 0x5e4a000 -  0x5e4bfff gate_1410.so 	/Library/Audio/Plug-Ins/LADSPA/gate_1410.so
 0x5e51000 -  0x5e52fff giant_flange_1437.so 	/Library/Audio/Plug-Ins/LADSPA/giant_flange_1437.so
 0x5e57000 -  0x5e5bfff gong_1424.so 	/Library/Audio/Plug-Ins/LADSPA/gong_1424.so
 0x5e67000 -  0x5e68fff gong_beater_1439.so 	/Library/Audio/Plug-Ins/LADSPA/gong_beater_1439.so
 0x5e6d000 -  0x5e7dfff gsm_1215.so 	/Library/Audio/Plug-Ins/LADSPA/gsm_1215.so
 0x5e94000 -  0x5e97fff gverb_1216.so 	/Library/Audio/Plug-Ins/LADSPA/gverb_1216.so
 0x5ea0000 -  0x5ea0fff hard_limiter_1413.so 	/Library/Audio/Plug-Ins/LADSPA/hard_limiter_1413.so
 0x5ea5000 -  0x5ea6fff harmonic_gen_1220.so 	/Library/Audio/Plug-Ins/LADSPA/harmonic_gen_1220.so
 0x5eab000 -  0x5eb2fff hermes_filter_1200.so 	/Library/Audio/Plug-Ins/LADSPA/hermes_filter_1200.so
 0x5ec2000 -  0x5ec4fff highpass_iir_1890.so 	/Library/Audio/Plug-Ins/LADSPA/highpass_iir_1890.so
 0x5eca000 -  0x5ecafff hilbert_1440.so 	/Library/Audio/Plug-Ins/LADSPA/hilbert_1440.so
 0x5ece000 -  0x5f8dfff imp_1199.so 	/Library/Audio/Plug-Ins/LADSPA/imp_1199.so
 0x5ff4000 -  0x5ff4fff impulse_1885.so 	/Library/Audio/Plug-Ins/LADSPA/impulse_1885.so
 0x5ff8000 -  0x5ff8fff inv_1429.so 	/Library/Audio/Plug-Ins/LADSPA/inv_1429.so
 0x5ffc000 -  0x5ffcfff karaoke_1409.so 	/Library/Audio/Plug-Ins/LADSPA/karaoke_1409.so
 0x6000000 -  0x6000fff latency_1914.so 	/Library/Audio/Plug-Ins/LADSPA/latency_1914.so
 0x6004000 -  0x6005fff lcr_delay_1436.so 	/Library/Audio/Plug-Ins/LADSPA/lcr_delay_1436.so
 0x600c000 -  0x600efff lowpass_iir_1891.so 	/Library/Audio/Plug-Ins/LADSPA/lowpass_iir_1891.so
 0x6014000 -  0x6015fff ls_filter_1908.so 	/Library/Audio/Plug-Ins/LADSPA/ls_filter_1908.so
 0x601b000 -  0x601bfff matrix_ms_st_1421.so 	/Library/Audio/Plug-Ins/LADSPA/matrix_ms_st_1421.so
 0x601f000 -  0x6020fff matrix_spatialiser_1422.so 	/Library/Audio/Plug-Ins/LADSPA/matrix_spatialiser_1422.so
 0x6025000 -  0x6025fff matrix_st_ms_1420.so 	/Library/Audio/Plug-Ins/LADSPA/matrix_st_ms_1420.so
 0x6029000 -  0x6029fff mod_delay_1419.so 	/Library/Audio/Plug-Ins/LADSPA/mod_delay_1419.so
 0x602d000 -  0x602efff multivoice_chorus_1201.so 	/Library/Audio/Plug-Ins/LADSPA/multivoice_chorus_1201.so
 0x6035000 -  0x6037fff notch_iir_1894.so 	/Library/Audio/Plug-Ins/LADSPA/notch_iir_1894.so
 0x603e000 -  0x6040fff phasers_1217.so 	/Library/Audio/Plug-Ins/LADSPA/phasers_1217.so
 0x6049000 -  0x604cfff plate_1423.so 	/Library/Audio/Plug-Ins/LADSPA/plate_1423.so
 0x6055000 -  0x6055fff pointer_cast_1910.so 	/Library/Audio/Plug-Ins/LADSPA/pointer_cast_1910.so
 0x605a000 -  0x605afff rate_shifter_1417.so 	/Library/Audio/Plug-Ins/LADSPA/rate_shifter_1417.so
 0x605e000 -  0x605ffff retro_flange_1208.so 	/Library/Audio/Plug-Ins/LADSPA/retro_flange_1208.so
 0x6067000 -  0x6068fff revdelay_1605.so 	/Library/Audio/Plug-Ins/LADSPA/revdelay_1605.so
 0x606e000 -  0x606ffff ringmod_1188.so 	/Library/Audio/Plug-Ins/LADSPA/ringmod_1188.so
 0x6075000 -  0x6076fff satan_maximiser_1408.so 	/Library/Audio/Plug-Ins/LADSPA/satan_maximiser_1408.so
 0x607b000 -  0x607dfff sc1_1425.so 	/Library/Audio/Plug-Ins/LADSPA/sc1_1425.so
 0x6085000 -  0x6087fff sc2_1426.so 	/Library/Audio/Plug-Ins/LADSPA/sc2_1426.so
 0x608f000 -  0x6091fff sc3_1427.so 	/Library/Audio/Plug-Ins/LADSPA/sc3_1427.so
 0x6099000 -  0x609bfff sc4_1882.so 	/Library/Audio/Plug-Ins/LADSPA/sc4_1882.so
 0x60a4000 -  0x60a6fff sc4m_1916.so 	/Library/Audio/Plug-Ins/LADSPA/sc4m_1916.so
 0x60af000 -  0x60b1fff se4_1883.so 	/Library/Audio/Plug-Ins/LADSPA/se4_1883.so
 0x60ba000 -  0x60bafff shaper_1187.so 	/Library/Audio/Plug-Ins/LADSPA/shaper_1187.so
 0x60be000 -  0x60c2fff sifter_1210.so 	/Library/Audio/Plug-Ins/LADSPA/sifter_1210.so
 0x60ca000 -  0x60cafff sin_cos_1881.so 	/Library/Audio/Plug-Ins/LADSPA/sin_cos_1881.so
 0x60cf000 -  0x60d0fff single_para_1203.so 	/Library/Audio/Plug-Ins/LADSPA/single_para_1203.so
 0x60d6000 -  0x60d6fff sinus_wavewrapper_1198.so 	/Library/Audio/Plug-Ins/LADSPA/sinus_wavewrapper_1198.so
 0x60da000 -  0x60dafff smooth_decimate_1414.so 	/Library/Audio/Plug-Ins/LADSPA/smooth_decimate_1414.so
 0x60de000 -  0x60defff split_1406.so 	/Library/Audio/Plug-Ins/LADSPA/split_1406.so
 0x60e2000 -  0x60e3fff step_muxer_1212.so 	/Library/Audio/Plug-Ins/LADSPA/step_muxer_1212.so
 0x60e8000 -  0x60e8fff surround_encoder_1401.so 	/Library/Audio/Plug-Ins/LADSPA/surround_encoder_1401.so
 0x60ed000 -  0x60eefff svf_1214.so 	/Library/Audio/Plug-Ins/LADSPA/svf_1214.so
 0x60f3000 -  0x60f4fff tape_delay_1211.so 	/Library/Audio/Plug-Ins/LADSPA/tape_delay_1211.so
 0x60fa000 -  0x60fbfff transient_1206.so 	/Library/Audio/Plug-Ins/LADSPA/transient_1206.so
 0x6100000 -  0x6102fff triple_para_1204.so 	/Library/Audio/Plug-Ins/LADSPA/triple_para_1204.so
 0x6109000 -  0x610afff valve_1209.so 	/Library/Audio/Plug-Ins/LADSPA/valve_1209.so
 0x610f000 -  0x6110fff valve_rect_1405.so 	/Library/Audio/Plug-Ins/LADSPA/valve_rect_1405.so
 0x6115000 -  0x6117fff vynil_1905.so 	/Library/Audio/Plug-Ins/LADSPA/vynil_1905.so
 0x6121000 -  0x6121fff wave_terrain_1412.so 	/Library/Audio/Plug-Ins/LADSPA/wave_terrain_1412.so
 0x6125000 -  0x6126fff xfade_1915.so 	/Library/Audio/Plug-Ins/LADSPA/xfade_1915.so
 0x612b000 -  0x612bfff zm1_1428.so 	/Library/Audio/Plug-Ins/LADSPA/zm1_1428.so
 0x612f000 -  0x6133fff vst-bridge.so 	/Applications/audacity3/plug-ins/vst-bridge.so
 0x6137000 -  0x613bfff vst-bridge.so 	/Users/Jno/Library/Audio/Plug-Ins/VST/vst-bridge.so
 0x61a6000 -  0x62f6fff com.ikmultimedia.CSR VPA 1.x (???)	/Library/Application Support/IK Multimedia/CSR/CSR.vpa/Contents/MacOS/CSR
 0x650a000 -  0x6553fff com.audiodamage.audiounit.914 1.0.2	/Library/Audio/Plug-Ins/Components/914.component/Contents/MacOS/914
 0x659b000 -  0x65bcfff com.ikmultimedia.audiounit.csrhall ??? (1.1)	/Library/Audio/Plug-Ins/Components/CSR Hall.component/Contents/MacOS/CSR Hall
 0x65e5000 -  0x6606fff com.ikmultimedia.audiounit.csrinverse ??? (1.1)	/Library/Audio/Plug-Ins/Components/CSR Inverse.component/Contents/MacOS/CSR Inverse
 0x662f000 -  0x6650fff com.ikmultimedia.audiounit.csrplate ??? (1.1)	/Library/Audio/Plug-Ins/Components/CSR Plate.component/Contents/MacOS/CSR Plate
 0x6679000 -  0x669afff com.ikmultimedia.audiounit.csrroom ??? (1.1)	/Library/Audio/Plug-Ins/Components/CSR Room.component/Contents/MacOS/CSR Room
 0x66ca000 -  0x6718fff com.audiodamage.RatshackReverb2_AU 2.0 (2.0.0.2)	/Library/Audio/Plug-Ins/Components/RatshackReverb2.component/Contents/MacOS/RatshackReverb2
 0x759d000 -  0x75a0fff com.apple.CarbonSpellChecker 1.0	/System/Library/CoreServices/CarbonSpellChecker.bundle/Contents/MacOS/CarbonSpellChecker
 0x75a4000 -  0x75a8fff com.apple.CommonCocoaPanels 2.0 (10)	/System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x70090000 - 0x700e6fff com.apple.LiveType.framework 1.2	/System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x8fe00000 - 0x8fe52fff dyld 46.16	/usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib 	/usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib 	/usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.82 (???)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35)	/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???)	/System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib 	/usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib 	/usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff com.apple.framework.IOKit 1.4 (???)	/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib 	/usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.18	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 4.0 (129.24)	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0)	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.8	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36)	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib 	/usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770)	/System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2	/System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib 	/usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3	/System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib 	/usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5	/System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 1.5 (297)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.11	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.27 (???)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???)	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 183	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.8	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib 	/usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib 	/usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d01fff libPng.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d06000 - 0x91d09fff libRadiance.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d0b000 - 0x91de9fff libxml2.2.dylib 	/usr/lib/libxml2.2.dylib
0x91e09000 - 0x91e47fff libTIFF.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91e4e000 - 0x91e4efff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2)	/System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e50000 - 0x91f35fff com.apple.vImage 2.4	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f3d000 - 0x91f5cfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2)	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fc8000 - 0x92036fff libvMisc.dylib 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x92041000 - 0x920d6fff libvDSP.dylib 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920f0000 - 0x92678fff libBLAS.dylib 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926ab000 - 0x929d6fff libLAPACK.dylib 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a06000 - 0x92af4fff libiconv.2.dylib 	/usr/lib/libiconv.2.dylib
0x92af7000 - 0x92b7ffff com.apple.DesktopServices 1.3.7	/System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bc0000 - 0x92df3fff com.apple.Foundation 6.4.11 (567.40)	/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f26000 - 0x92f44fff libGL.dylib 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f4f000 - 0x92fa9fff libGLU.dylib 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x92fc7fff com.apple.Carbon 10.4 (???)	/System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fc9000 - 0x92fddfff com.apple.ImageCapture 3.0	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ff5000 - 0x93005fff com.apple.speech.recognition.framework 3.4	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93011000 - 0x93026fff com.apple.securityhi 2.0 (203)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93038000 - 0x930bffff com.apple.ink.framework 101.2 (69)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930d3000 - 0x930defff com.apple.help 1.0.3 (32)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930e8000 - 0x93116fff com.apple.openscripting 1.2.7 (???)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93130000 - 0x9313ffff com.apple.print.framework.Print 5.2 (192.4)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9314b000 - 0x931b1fff com.apple.htmlrendering 1.1.2	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931e2000 - 0x93231fff com.apple.NavigationServices 3.4.4 (3.4.3)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9325f000 - 0x9327cfff com.apple.audio.SoundManager 3.9	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9328e000 - 0x9329bfff com.apple.CommonPanels 1.2.2 (73)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932a4000 - 0x935b2fff com.apple.HIToolbox 1.4.10 (???)	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93702000 - 0x9370efff com.apple.opengl 1.4.7	/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93787000 - 0x93787fff com.apple.Cocoa 6.4 (???)	/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93789000 - 0x93dbcfff com.apple.AppKit 6.4.10 (824.48)	/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94149000 - 0x941bbfff com.apple.CoreData 91 (92.1)	/System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941f4000 - 0x942b9fff com.apple.audio.toolbox.AudioToolbox 1.4.7	/System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9430c000 - 0x9430cfff com.apple.audio.units.AudioUnit 1.4	/System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9430e000 - 0x944cefff com.apple.QuartzCore 1.4.12	/System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94518000 - 0x94555fff libsqlite3.0.dylib 	/usr/lib/libsqlite3.0.dylib
0x9455d000 - 0x945adfff libGLImage.dylib 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945b6000 - 0x945cffff com.apple.CoreVideo 1.4.2	/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9477d000 - 0x9478cfff libCGATS.A.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94794000 - 0x947a1fff libCSync.A.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x947e7000 - 0x94800fff libRIP.A.dylib 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94807000 - 0x94b39fff com.apple.QuickTime 7.6.0 (1290)	/System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c21000 - 0x94c92fff libstdc++.6.dylib 	/usr/lib/libstdc++.6.dylib
0x95069000 - 0x95086fff libresolv.9.dylib 	/usr/lib/libresolv.9.dylib
0x9579f000 - 0x9585afff com.apple.WebKit 523.12.2	/System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x958c3000 - 0x95976fff com.apple.JavaScriptCore 523.12	/System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9599e000 - 0x95f1bfff com.apple.WebCore 523.12.2	/System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x97658000 - 0x97677fff com.apple.vecLib 3.2.2 (vecLib 3.2.2)	/System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97e6c000 - 0x97e79fff com.apple.agl 2.5.6 (AGL-2.5.6)	/System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x99283000 - 0x99f3cfff com.apple.QuickTimeComponents.component 7.6 (1290)	/System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9ae77000 - 0x9ae95fff com.apple.OpenTransport 2.0	/System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x9c6ec000 - 0x9c70cfff libmx.A.dylib 	/usr/lib/libmx.A.dylib
0x9ff42000 - 0x9ffe3fff com.apple.QuickTimeImporters.component 7.6 (1290)	/System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
Model: PowerMac8,1, BootROM 5.2.2f4, 1 processors, PowerPC G5  (3.0), 1.8 GHz, 1.25 GB
Graphics: GeForce FX 5200, GeForce FX 5200, AGP, 64 MB
Memory Module: DIMM0/J4000, 1 GB, DDR SDRAM, PC3200U-30440
Memory Module: DIMM1/J4001, 256 MB, DDR SDRAM, PC3200U-30330
AirPort: AirPort Extreme, 405.1 (3.90.34.0.p18)
Modem: Jump, V.92, Version 1.0
Network Service: AirPort, AirPort, en1
Serial ATA Device: SAMSUNG HD160JJ, 149.05 GB
Parallel ATA Device: MATSHITADVD-R   UJ-825
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Apple Optical USB Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
what now? thanks so much
Post by kozikowski » Mon Apr 13, 2009 10:30 pm
I don't have any good answers. VST support has always been a little ratty in Audacity. Try the Advanced Search at the top of this forum.
And please don't post hundreds of pages of core dump without asking first. The forum isn't all that big.
Post by steve » Thu Apr 16, 2009 2:39 pm
Audacity achieves (partial) VST support using the "VST Bridge" plug-in (a separate open source project). The VST bridge is not compatible with all VST plug-ins, and will cause a crash in the presence of some.
My personal opinion, is to not use VST on Audacity, and stick with the hundreds of free LADSPA and Nyquist plug-ins, but if you really must use VST with Audacity, then the solution is to uninstall ALL VST plug-ins from your computer, then add them back one at a time, until you find which are causing the problem.
kozikowski wrote:And please don't post hundreds of pages of core dump without asking first.
Or at least use the "Code" button to put it into a code box, then koz probably won't notice, and it keeps the forum page a lot more readable.
