How to remove lyrics from music
Hi, I am new to audacity. I would like to remove the lyrics to a mp3 song so I can do a song parody at a party. Would someone tell me how to do this? I am using a i Mac Intel based. Thank you
Re: How to remove lyrics from music
Vocal Removal is harder to do than you would think. There are a lot of rules -- like the show has to be in stereo and the singer has to be in the middle with no echo or special effects -- and and generally, MP3 compressed files have problems doing it. But here are the tools:
Voice Removal or Isolation
--Center Pan Remover (Voice Remover--Search the page for "Center Pan Remover")
http://audacityteam.org/download/nyquistplugins
--Voice Trap
http://www.cloneensemble.com/vt_main.htm
--Extra Boy
http://www.kvraudio.com/get/1651.html
--Kn0ck0ut
http://www.freewebs.com/st3pan0va/
You can download my Left-Right sound test to see if you're doing it right...
http://www.kozco.com/tech/soundtests.html
If your tools are working, segment three "mono" will vanish leaving one, two and four.
--Voice Trap
--Extra Boy
--Kn0ck0ut
