MP3 Export problem
This section is now closed
satkin2
MP3 Export problem
Post by satkin2 » Fri Mar 13, 2009 8:18 pm
Hi,
I've regularly exported to mp3 and never noticed if this happened before, but what I'm exporting for now requires more precision than usual. I've got my track to the length I want (13 seconds). When I export to mp3 it does export ok but the length of the track extends to 15 with the last 2 seconds being silence.
Why is Audacity adding these 2 seconds to the track? Is there a way to stop it doing this?
Re: MP3 Export problem
Post by kozikowski » Sat Mar 14, 2009 3:45 am
Lets cast our minds back. Where did this/these tracks come from? Live performance into a microphone mixer and then into the Line-In of your Mac?
satkin2
Post by satkin2 » Sat Mar 14, 2009 8:52 am
This is a short file that was recorded using the line in.
Although it isn't ideal I have found a work around, trimming the added 2 seconds in Audion and then resaving as an mp3.
Post by kozikowski » Sat Mar 14, 2009 6:20 pm
Yes, that's a very poor work-around because MP3 takes its pound of flesh each time you go in and out.
Do you get the same problem with exporting a WAV? The desperation method is export a WAV and convert to MP3 somewhere else. That will be far higher quality (but won't solve the problem).
satkin2
Post by satkin2 » Sun Mar 15, 2009 9:18 pm
Hi,
Yes unfortunately exporting to .wav produces the same problem.
The Audion work around isn't any good either as the program is very buggy and after using a few times won't open.
