which is the correct version to use
This section is now closed
sbs
Post by sbs » Fri Feb 06, 2009 5:11 am
I have a macbook pro (X 10.5) and am not sure whether to download 1.25 or 1.36.
Re: which is the correct version to use
Post by kozikowski » Fri Feb 06, 2009 6:58 am
Both. Up until last week, I had 1.2.5 and 1.3.7-experimental on this (Intel Mini) at the same time.
I can't use them at the same time, but they're both installed.
This is highly recommended because the Mac versions of 1.3.7 (the current version) are a little wacky.
If you do find 1.3.6, that's the one to use for a while, until 1.3.8 comes out with all the patches and fixes--that the developers are writing right now.
The rule of thumb is 1.2.5 is stable and good if you need something to record your performance, Export a Safety WAV, cut it up a little, and Export a final capture WAV file. If you need heavy processing, then that's where 1.3.x shines, but have that backup WAV of your work in case Something Happens.
Audacity doesn't Save sound files.
