I can hear everything when recording
This section is now closed
NOLU
Post by NOLU » Mon Feb 02, 2009 6:33 pm
Hiya.
I've just began to use Audacity with decks and a DJM 400 mixer. I have the two RCA's plugged in to the mixer and the single jack in to the headphone socket of a Mac. The version is 1.2.5 and the Mac is OS X 10.
The problem I'm having is I want to just record what I'm playing through the mixer but I hear every noise around me, myself, the click of a mouse etc. Would you know what I should do to be able to stop hearing every sound and just record and play back what I'm playing through the mixer?
Thanks.
Re: I can hear everything when recording
Post by kozikowski » Mon Feb 02, 2009 9:12 pm
Just because I'm compulsive about this, you are not plugged into the "headphone" connector. Chances are, you're plugged into the Mac Line-In which is the connector labeled the little black circle and two black arrows pointing in.
Given that, you are recording your built-in microphone, not the show from the mixer.
Apple > System Preferences > Hardware > Sound > Input. Select where you want the show to come from and close the panel. Then it's Audacity > Preferences > Audio I/O > Recording > Built In Audio. Close the panel and restart Audacity.
The actual Audacity recording panel might say something like Default Input. That's OK. Just go with it.
Post by kozikowski » Mon Feb 02, 2009 9:14 pm
One other trick. You don't have to press Record in Audacity to see what the levels are. You can click once inside the red record meters and they will wake up and show you the levels.
It's one of Audacity's built-in diagnostic modes.
NOLU
Post by NOLU » Tue Feb 03, 2009 10:14 pm
Nope. It was the headphone socket but thanks for the answer :) It's now all sorted and I can record just off the mixer.
Cheers ;)
Post by kozikowski » Tue Feb 03, 2009 10:54 pm
<<<headphone socket of a Mac.>>>
That's still rough to believe.
Which Mac?
Apple > About This Mac > More Info > Hardware > Machine Name
And what exactly did you do to fix it? Remember this is an all volunteer cast of thousands so you need to share how you fixed your problem.
NOLU
Post by NOLU » Wed Feb 04, 2009 10:29 am
Sorry I wasn't clear.
I was making the mistake initially of putting the lead in the headphone socket next to the mac Line in that you mentioned. I followed your instructions and it works fine so thanks again.
