Hello,
I just installed audacity 1.2.6 - UmixIt version (downloaded the "audacity-macosx-ppc-1.2.6a.dmg") and the application doesn't allow me to export any document in any format. I can open the dialog window to export, but the "save" button is not selectable.
I have a Mac PPC G5 with OSX 10.3.9
Thank you for your help.
Etienne
The problem was that the software did not let me save on the root of my hard disk
Can't export (create a .wav or .aiff document) - solved
Re: Can't export (create a .wav or .aiff document)
In Audacity, there is a very significant difference between Export and Save, but they should not be gray.
Applications > Utilities > Disk Utilities > Select your system drive > Repair Permissions.
Restart Audacity.
If that doesn't work, trash the Audacity folder...
Users > Etienne > Library > Application Support > Audacity
Restart Audacity.
If that doesn't work, trash the Application and support files and the above folder and get Audacity fresh from...
http://audacityteam.org/
Restart Audacity.
Restart Audacity.
Re: Can't export (create a .wav or .aiff document) - solved
Don't change the original posting when you discover something new. Post an additional message, so we have a "paper trail" instead of scrambled question and answer.
