Hi
Can i add track markers to a mix i have recorded into audacity? (this is a continuous mix with no gaps recorded via two decks and a mixer), so when i export as a wav and then burn to cd as an audio cd, listeners will be able to skip tracks within the mix.
I have a feeling I can't but confirmation would be appreciated
Thanks
Track markers
Re: Track markers
You can get the same result, but through a different method.
See here:
http://audacityteam.org/wiki/index.php? ... ate_tracks
See here:
waxcylinder
Re: Track markers
And you may need to set your CD burner software so that it does not insert 2-second (may vary) intertrack gaps, so that you retain your continuous mix.
