"Unable to open target file for writing"
This section is now closed
joeo
Post by joeo » Tue Dec 30, 2008 5:32 am
I have just upgraded to a macbook pro from a g3 ibook. I had been digitizing my vinyl with an ion usb turntable and audacity 1.2.6 on the old laptop, recording and exporting (to mp3) without incident. When I try to use the new mac i am unable to export the files to mp3, I get the error message "Unable to open target file for writing". I tried using 1.2.6/lamelib at first and then downloaded audacity 1.2.5/libmp3lame.dylib (for intel macs). I had the same issues with both versions. I have been able to record songs, just not export them. I also have a bunch of songs i had previously recorded on the old laptop (and moved over to the macbook pro) that i hadnt exported yet and these gave me the same error message. The .aup and _data files are both present.
Thanks in advance for any help solving this problem!
Re: "Unable to open target file for writing"
Post by kozikowski » Tue Dec 30, 2008 7:40 pm
I thought this had come up before.
http://audacityteam.org/forum/viewtopic ... ile#p31708
Underscore and dash are the only two punctuation marks allowed in computer file names. Some Macs will allow other marks (/, ?, !), but that's a recipe for disaster. The truly compulsive will not use spaces, either.
My_really_great_Christmas-Music.wav
Our company has a convention of leading caps.
MyReallyGreatChristmasMusic.wav
joeo
Post by joeo » Wed Dec 31, 2008 7:57 am
Thanks Koz
I missed that topic in the forums when I looked before I posted. From your post I was able to rule out the file name issue and the fragmented drive issue. I did resolve the problem, it was actually an issue with the permissions in the folder i had the files in since I had copied it over from the old laptop. So, a new destination for the exported mp3 and problem solved! Thanks very much and happy new year!
Joe
Post by kozikowski » Thu Jan 01, 2009 12:23 am
Have you tried Verify Disk and Repair Permissions in Applications > Utilities > Disk Utilities?
If you have an older machine, you may need to restart the machine on your install CD (Put the CD in and hold "C" during startup and release it when the Apple appears). Then go into the utilities and run Disk Utilities from there.
