I exported Audacity wav files to my i-Tunes libary on my i-Mac. I then downloaded the songs to my i-Pod. When playing the songs back on the i-Pod they just skip to the end. Here is the interesting thing: I have transferred about 10 LPs to my i-Tunes library using Audacity and all work fine on my i-Pod with the exception of the albums that I transferred on one particular day (3 albums). The same songs/albums do not play properly on both my classic and nano so it is not the i-Pod. However, the songs play fine when I play the i-Pod through the i-Mac. It is only when I disconnect the i-Pod and attempt to play the songs from the device that I have a problem. But again, it is only the albums I transferred on one particular day. Unfortunately I cannot see any difference in terms of how the songs from the bad albums were transferred vs. the ones that play fine. It looks the same to me and I followed the same procedure.
What am I doing wrong? Any suggestions?
Thanks,
Scott
songs skipping on iPod but playing fine on Mac
Re: songs skipping on iPod but playing fine on Mac
How do you get applications on ipod touch? How do you put the applications- like the ones in the apple apps store- onto your ipod touch? I have a first generation ipod touch.
