Converting Dual Mono to Mono
This section is now closed
NY2LA
Post by NY2LA » Sat Oct 01, 2011 10:50 pm
I digitized numerous analog cassette tapes, consisting of spoken word as dual mono, with GarageBand. The resulting files are AIFF files with standard Linear PCM as 2 channels. The left channel is typically louder; the audio was recorded like that on the original tapes.
I want to convert the AIFF files to WAV files with 1 channel. However, I do not want to batch process, and I do not want the resulting single channel to be the "sum" (?) of the two channels.
I want to examine each AIFF file, look at levels, etc., and make a decision to use one or the other channel, as the mono channel in the WAV file that I will create.
Can I do this with Audacity?
Re: Converting Dual Mono to Mono
Post by Gale Andrews » Sat Oct 01, 2011 11:33 pm
NY2LA wrote:I digitized numerous analog cassette tapes, consisting of spoken word as dual mono, with GarageBand. The resulting files are AIFF files with standard Linear PCM as 2 channels. The left channel is typically louder; the audio was recorded like that on the original tapes.
Click in the name of the track to left of the waveform to access the Track Drop-down menu and choose "Split Stereo Track".
Use the [X} to left of the track to delete the unwanted channel.
Use the same menu to make the remaining channel mono.
Are you really using Audacity 1.2 as your post indicates? If you are on OS X 10.4 or later, 1.3.13 Beta is much preferred. The .dmg installer for 1.3.13 provides a built-in Manual. You can access it at Help > Manual (in web browser) in the program.
NY2LA
Post by NY2LA » Sat Oct 01, 2011 11:54 pm
Thanks.
Yes, I downloaded and installed Audacity 1.2.5 on my iMac (Intel) earlier today. Okay, I'll give the beta a try. Do you know whether I should delete 1.2.5 first?
P.S. For some reason, the "About . . ." feature is grey.
Post by kozikowski » Sun Oct 02, 2011 3:23 pm
After you split the stereo track in two, you can use the Mute and Solo buttons at the left to listen to one or the other to decide which to keep. Then [X] delete the unwanted one and using the left drop-down menus, make the remaining one Mono. Export.
You can also use the Duplicate Track (Edit > Duplicate) to make two copies of the hero track and Make Stereo Track from the left drop-downs. This will effectively give you a new stereo track with the one good work on both. Export
Audacity will not Save a sound file. You have to Export one. If you have room, WAV or AIFF is preferable for archive work. You can't easily make an MP3 from an MP3, so digging up an old MP3 show and folding it into a new production may cause problems.
Audacity 1.2 is very old and no longer supported,
patched, corrected, or updated. Audacity 1.2 can
be unstable on newer computers.
Download and install the latest Audacity 1.3 from here...
You can install both audacity 1.2 and Audacity 1.3 on
the same computer, but only use one at a time.
Audacity 1.2 will not open projects made on Audacity 1.3.
If you use MP3 or some of the more modern audio
compression formats, get Lame and FFMpeg software
from the same web site. Do not use older software
or software from other web sites, even though they
may have the same names.
Post by kozikowski » Sun Oct 02, 2011 6:53 pm
Audacity > About is gray. About is hidden under Help where the rest of the world puts it.
NY2LA
Post by NY2LA » Sun Oct 02, 2011 7:45 pm
I've installed Audacity 1.3.13, tried out the aforementioned steps, and I like it a lot.
Is the Metadata Editor allowing me to embed text based data in the WAV file using the RIFF List Info format? (Perhaps you can provide a link to information about this.)
Thanks.
Post by Gale Andrews » Sun Oct 02, 2011 8:19 pm
NY2LA wrote:Is the Metadata Editor allowing me to embed text based data in the WAV file using the RIFF List Info format?
Yes, but the range of RIFF List Info tags is relatively limited compared to ID3 and does not support custom tags. Also Audacity only supports a subset of the List Info tags. See:
http://wiki.audacityteam.org/wiki/WAV#Metadata
AIFF (also lossless) will give you a better range of tags and AIFF (though not Audacity) also supports embedded lyrics and images.
kozikowski wrote:About is hidden under Help where the rest of the world puts it.
I don't know for sure about 1.2, but the Beta version definitely has "About" under the "Audacity" menu on Mac:
http://manual.audacityteam.org/man/Audacity_Menu
NY2LA
Post by NY2LA » Sun Oct 02, 2011 9:54 pm
Gale Andrews wrote: AIFF (also lossless) will give you a better range of tags and AIFF (though not Audacity) also supports embedded lyrics and images.
I'm surprised about this, because I was under the impression that WAV has better support for metadata. Perhaps I am thinking of Broadcast Wave?
Gale Andrews wrote: I don't know for sure about 1.2, but the Beta version definitely has "About" under the "Audacity" menu on Mac:
Indeed.
Post by Gale Andrews » Mon Oct 03, 2011 1:18 am
Broadcast WAV metadata as I understand it is very specialised, to do with radio automation, database archiving and file synchronisation/exchange. Besides, iTunes doesn't recognise any metadata in WAV files of any sort.
NY2LA
Post by NY2LA » Mon Oct 03, 2011 6:38 am
I think I'll use those RIFF Info fields that Audacity supports.
How many characters allowed in Comments? 256?
It's a shame that not many players read this metadata. Maybe that situation will improve, considering Audacity and Adobe Audition support it.
