Exporting measurements?
This section is now closed
jahamel
Post by jahamel » Thu Jul 31, 2008 12:12 am
Hi there,
I am using Audacity to measure the durations and rates of sounds. (A great many sounds.)
Right now, I am laboriously selecting each sound on the track and then typing the start and end points into an Excel spreadsheet.
Is there a function that will let me just copy and paste these measurements?
Boy, that would be *extremely* helpful.
Thanks
Re: Exporting measurements?
Post by kozikowski » Thu Jul 31, 2008 1:47 am
The numbers inside the time and duration panels don't cut and paste, do they? There's a feature request for the next Audacity.
Post by steve » Thu Jul 31, 2008 2:09 am
You could try using the "Silence Finder" from the Analysis menu in Audacity 1.3.x, and then exporting the resulting label track. This may or may not help you.
jahamel
Post by jahamel » Thu Jul 31, 2008 4:16 am
Thanks - Silence Finder will not help me this time (too much wind noise, they are field recordings), but maybe in the future.
waxcylinder
Post by waxcylinder » Thu Jul 31, 2008 8:57 am
Building on Steve's reply:
1) switch to Audacity 1.3.5
2) create al label for each track - find them by hand as you are doing now, as you point out the silence finder wil probably not hepl you
3) Use the File > Export Labels function
4) This will give you a text file (which on Windows you can open with Excel - don't know how or if this works on MACs)
There is still some typing involved (i.e. the labels) but probably less than you are doing now ....
jahamel
Post by jahamel » Thu Jul 31, 2008 2:21 pm
Hi waxcylinder,
Thanks - this looks extremely helpful. One more question: Is there a way to set the export format to hh:mm:ss.000 (the same format that the time and duration panels use)? I do not see an easy way to do this, but maybe I am missing something...
Cheers,
Jen
waxcylinder
Post by waxcylinder » Thu Jul 31, 2008 3:43 pm
Jen,
no I don't see a way to do this either - the ouput is in seconds and that's it.
I can see a feature request coming from you ......
Post by steve » Thu Jul 31, 2008 3:52 pm
Since you are putting them into an Excel document, you could probably use a formula in Excel to convert from seconds into your desired format.
