Hi --
I can record in audacity with the built-in mics on my computer, but when I try to record into audacity using my presonus firebox, i get the message "error while opening sound device." I've tried all the different sample rates and bit depths (via preferences). i've tried using the firebox as a handler for all of my sounds in the OS, and using it only in audacity (selecting it in preferences as my audio device.) Nothing works. Any thoughts?
can't record from firebox (error while opening sound device)
Re: can't record from firebox (error while opening sound dev
Anything in this topic help? http://audacityteam.org/forum/viewtopic ... box#p18180
