.aiff and .mpeg
This section is now closed
fd7760
.aiff and .mpeg
Post by fd7760 » Tue Nov 09, 2010 11:32 pm
When I try to save a recording I've made from a cassette, and choose SAVE AS AIFF or MPEG, I continually get this message saying that "files with a dot before them are reserved for the system and the file will be hidden." I work on an iMac using 10.4.11. It's driving me mad! Can someone please help?
billw58
Re: .aiff and .mpeg
Post by billw58 » Tue Nov 09, 2010 11:56 pm
First, I highly recommend that you upgrade to 1.3.12 http://audacityteam.org/download/beta_mac
Second, all you have to do is give the file a name - something that is before the ".aiff" or ".mpeg".
-- Bill
fd7760
Re: .aiff and .mpeg
Post by fd7760 » Wed Nov 10, 2010 1:47 pm
Bill :Of course! Thank you very much for taking the time to respond.
fd7760
Separating Tracks
Post by fd7760 » Wed Nov 10, 2010 7:57 pm
You've been very helpful. With any luck, this is my last question (at least for a while). I successfully recorded a CD from a cassette. BUT how do I separate the tracks? In essence, to record the cassette, I started the deck, then Audacity, then walked away. When I import it into iTunes, it does so as one (long) song. Without monitoring the computer and manually creating separate tracks, is there a way to do it once the recording is over?
Re: .aiff and .mpeg
Post by steve » Wed Nov 10, 2010 8:01 pm
