plug-in
This section is now closed
santosestrella
plug-in
Post by santosestrella » Mon Nov 08, 2010 2:31 am
HOW DO YOU INSTALL PLUG-INS. THE SITE SAID TO INSTALL IN THE APPLICATIONS FOLDER. I OPEN THE AUDACITY APP IN THE APPLICATION FOLDER AND PASTED IT INSIDE. NOTHING HAPPENS
PLEASE HELP.
THANKS
billw58
Re: plug-in
Post by billw58 » Mon Nov 08, 2010 2:35 am
Which site said that?
http://audacityteam.org/download/plugins says
"To install new plug-ins, place them in the Plug-Ins folder inside the Audacity installation folder".
The recommended installation for Audacity on OS X is to create a folder inside the Applications folder called something like "Audacity". Then drag everything from the Audacity dmg that you download from here http://audacityteam.org/download/beta_mac into that folder. That will install the "plug-ins" folder for you.
No need to install anything inside of "Audacity.app". In fact, I'd trash your installation and do it again, as recommended.
Note that I am recommending 1.3.12 over any 1.2.x version for OS X.
-- Bill
