unsuccessful import from GarageBand
This section is now closed
broncosmitty
Post by broncosmitty » Tue Oct 19, 2010 6:52 pm
I have a long single GarageBand ('09, ver. 5.1) track that I want to manipulate in Audacity (1.3.8) on my imac (Intel Core 2 Duo 2GHz).
I get the message "Error opening file" when I attempt to just open the GarageBand file, an error saying "Audacity did not recognize the type of file..." when just plain importing it, an upon Importing the GarageBand file as Raw Data, nothing shows up on the sound palette.
Any idea what I'm doing wrong?
broncosmitty
Re: unsuccessful import from GarageBand
Post by kozikowski » Tue Oct 19, 2010 8:00 pm
Open the file in QuickTime Player and Command-I to get the INFO panel. What does that say, what kind of file?
You should not be in Audacity 1.2. 1.2 is not supported on modern Macs. Get Audacity 1.3.12 from here...
http://audacityteam.org/download/beta_mac
If Garage Band is expecting to send the music directly to iTunes, it may be in the Apple AAC format. You can get iTunes to translate into WAV. Let us know. Does Garage Band have an export option list? Pick AIFF or even better WAV format.
broncosmitty
Post by broncosmitty » Tue Oct 19, 2010 8:58 pm
I might have solved the problem. I saved the GarageBand file as an ACC file, and Audacity liked that much better.
I am in a working environment that disallows download from many sites, including Soundforge. I found the 1.3.8 (unicode) version on the Apple.com site. That worked for a download.
Thanks for the reply,
broncosmitty
Post by kozikowski » Tue Oct 19, 2010 9:16 pm
AAC, maybe? Advanced Audio Coding?
broncosmitty
Post by broncosmitty » Wed Oct 20, 2010 2:42 pm
Yes, AAC.
Broncosmitty
benallen
Post by benallen » Fri Oct 22, 2010 11:59 pm
What exactly is AAC and why is it better than MP3?
Post by Gale Andrews » Sat Oct 23, 2010 12:36 am
benallen wrote:What exactly is AAC and why is it better than MP3?
http://wiki.audacityteam.org/wiki/M4A
waxcylinder
Post by waxcylinder » Sat Oct 23, 2010 11:41 am
AAC is Apple's compressed format. It is generally reckoned to give better audio quality than MP3 for the same compression rates and filesizes (this diffenec declines when less compression is used - i.e higher bitrates)
MP3 has the key advantage that it is far more portable (i.e. will play on more suudio s/w and hardware music players) than AAC
Generally I would say that if you are a committed iTunes/iPod user the AAC is the way to go (and I do note that this is the MAC section of the forum ...) - otherwise use MP3.
Post by steve » Sun Oct 24, 2010 7:18 pm
waxcylinder wrote:AAC is Apple's compressed format. It is generally reckoned to give better audio quality than MP3 for the same compression rates and filesizes (this diffenec declines when less compression is used - i.e higher bitrates)
The test results that I've read indicate that there is little significant difference in sound quality at bit rates of 128 kbps or higher.
Overall rating: The results for each sample were grouped together without modifications.
Then I performed an ANOVA analysis. The results are graphed below. They show that all encoders are tied on first place, except l3enc which of course comes out last being the low anchor.
http://listening-tests.hydrogenaudio.or ... esults.htm
mandyslater100
Post by mandyslater100 » Mon Oct 25, 2010 1:59 pm
Well I would say that 128 bit AAC sounds better than 128 bit MP3, but there is still a noticeable difference if you go for a higher bitrate. That's why Apple offer higher bitrate downloads in the itunes store.
