No sound when exported as mp3 or aiff
This section is now closed
richiedelf
Post by richiedelf » Sat Oct 09, 2010 5:54 pm
I recently recorded a mix tape. I listened back to it and exported as an aiff and a mp3. But when I play it back on a media played there is no sound other than a little white noise. I have found the recording in 1meg parts in my documents folder as .au files. How do i get a copy of my mix tape? Please help me get this sorted, as I need to get it to a number of promoters pronto!!!!!
Thanks.
Richie
richiedelf
Re: No sound when exported as mp3 or aiff
Post by richiedelf » Sat Oct 09, 2010 5:55 pm
By the way...... Where I saved as the aiff file.... It's taking up 250 Mb of disc space. So it must be there? No?
Very confused!
Post by kozikowski » Sat Oct 09, 2010 5:59 pm
I think the first thing I'd do is stop using Audacity 1.2. It's not supported on modern Macs. If you Saved your work as a Project, it should open up in Audacity 1.3.12 which you can get from here...
http://audacityteam.org/download/beta_mac
Then Export as WAV or AIFF or anything else.
You can install both versions of Audacity, but only use one at a time.
Post by kozikowski » Sat Oct 09, 2010 6:00 pm
Are you using AIFF files for a specific reason? Audacity defaults to Microsoft WAV format because it's perfectly supported on all three computer types.
richiedelf
Post by richiedelf » Sat Oct 09, 2010 6:41 pm
Thanks Koz...
It's actually an old mac, power pc. and it only has a 1 gig processor. I though I was using the right version..... Do you think it will work with the newer version of the software?
Richie
richiedelf
Post by richiedelf » Sat Oct 09, 2010 7:10 pm
Tried what you suggested with the more recent version. No joy unfortunately. Any more ideas?
R
richiedelf
Post by richiedelf » Sat Oct 09, 2010 7:44 pm
Fixed it! Thanks for the help :D :D :D :D
Post by kozikowski » Sat Oct 09, 2010 10:02 pm
No, no, no! You need to tell us what worked! This is not a help desk. It's a dialog. You tell us what worked so we can help other people with your solution
