Hello,
I've successfully downloaded LameLib from
http://audacityteam.org/help/faq?s=inst ... m=lame-mp3
which gives me something called libmp3lame.dylib happily nestled in the Audacity folder in my Apps.
Alas, when I go to "File-->Export as mp3" and point Audacity to libmp3lame.dylib 's location, libmp3lame.dylib is greyed out and hence unavailable to do the exporting job.
Quitting and re-starting Audacity doesn't help.
Please give me the piece of the puzzle I'm missing!
TIA, Ch.S.
Export as .mp3 via LAME
billw58
Re: Export as .mp3 via LAME
Make sure you have the right LAME for your version of Audacity.
If you are running 1.2.x on a PPC machine you need LameLib-Carbon.sit from http://lame.buanzo.com.ar/
If this does not fix your problem please let us know the kind of Mac you have (G4, G5 or Intel), which version of OS X, and which version of Audacity.
-- Bill
-- Bill
I would not be doing either one of those things. Audacity 1.2 is no longer supported on modern computers and it won't run at all on some Macs.
http://audacityteam.org/download/beta_mac
You can safely install both versions, but only use one at a time. Audacity 1.3 Projects will not open in 1.2
Also download that particular lame version and let it install itself.
