As with many of the individuals with questions, I am a bit new to Audacity, so apologies in advance if this question is stupid.
I am in the early stages of using Audacity to digitize a vinyl LP collection. The first 2 recordings worked well. However, on the third, when I try to delete (or cut) portions of the recording (for example, leading noise before the music begins or excess space between songs/album sides), neither the delete or cut functions do what they are supposed to do -- simply remove the selection and advance the part of the clip after the deletion to the point where the beginning of the deletion was originally positioned.
What I get instead, is a normal delete, but with an overwrite of silence that appears to be about the same length as the delete (plus about 1/2 second) from the point where the delete took place (or was supposed to take place). I closed the project in question, closed Audacity, rebooted my machine. The problem continued. I closed everything and reloaded an earlier project that had been saved just after recording. NO Problem with the delete!
I am mystified. Any ideas?
Many thanks,
Bill
PS I have gone through the manual "selection" and "edit menu" sections with no joy. Also the problem pesists when I try to delete with the delete key, a keyboard shortcut or the "delete" item on the Edit Menu Bar.
My set-up: Intel iMac running OSX 10.6.4, with Audacity 1.3.12 (beta -- Unicode). I recorded the music direct from a pre-amp equipped turntable using the same version of Audacity on my laptop (black MacBook also running OSX 10.6.4), saved the Audacity Project into my iMac's drop box over a home wireless network, and opened the project directly from the drop box using the copy of Audacity on my iMac. I am using the two computers so that I can record at the same time that I am processing an earlier recording, and because (i) the turntable is a long ways away from the iMac and (ii) it is vastly easier to edit the recording on a larger screen (the iMac), with a mouse rather than trackpad, and with computer that has a larger memory (and, thus, operates more quickly).
"Delete" misbehaves
Re: "Delete" misbehaves
<<<I recorded the music direct from a pre-amp equipped turntable >>>
That doesn't get your turntable into the Mac. How do you do that? Analog connection into the Line-In or USB?
If you switch the MacBook to recording from the built-in microphone, can you edit that recording OK?
billw58
My guess is that the project file has somehow become corrupted. The fact the only one project misbehaves points to this. Open the problem project and a new project. Copy and paste the track from the problem project into the new project. Save the new project with a different name. Now try your edits. Does it work?
-- Bill
-- Bill
