Hola,
I'm using Audacity 1.2.5 on a Mac OSX 10.6.4.
I have this weird bug: I want to "Save as..." my project or I want to export a track from a project ("Save as .wav/mp3/...). The Save as-form opens and the project is in the background, but when I then type a Space into the name for instance, the track begins to play, other letters delete the selected track i want to export or change somethinge in the track, which I can see happening in the background. So somehow the keyboard-shortcuts then take effect although i'm in the Save As-form. It's really annoying and I could'nt find a answer to this problem anywhere in the forum or on the net. What is wrong with my audacity?
thanxx
Save As Bug
SenorEvergreen
billw58
Re: Save As Bug
You're using 1.2.5. Upgrade to 1.3.12 and the problem will go away. 1.2.x is no longer being updated, so this bug will not be fixed.SenorEvergreen wrote:What is wrong with my audacity?
-- Bill
SenorEvergreen
Re: Save As Bug
aight, will do this. thanx
