Recording sound file to macbook pro
This section is now closed
tarmstrong
Post by tarmstrong » Sun Sep 05, 2010 11:17 pm
I have a macbook pro the only recording preference as far as I can determine is the built in microphone, I wish to record direct an audio file direct from my Yamaha keyboard. Is this possible?
Re: Recording sound file to macbook pro
Post by kozikowski » Mon Sep 06, 2010 12:06 am
If you look in Apple > System Preferences > Hardware > Sound > Input, you should see two listings. Built-In Audio Input or Line-In in addition to the microphone.
Plug in your keyboard with one of these if you have RCA connections...
http://www.monoprice.com/products/produ ... 1&format=2
You should be able to play the keyboard and the Apple bouncing ball sound meter should bounce. Open Audacity and set 'Built-In Audio' in Audacity Preferences. Then restart Audacity. That's it. You should be able to record the keyboard performance.
If, like me, you only have the keyboard headphone out, it's a little more involved. Let me know.
