Helllloooo!
I recently downloaded Audacity and I'm trying to get some voice overs recorded.
I went to the preferences and changed my input device to the presonus firestudio.. I also did this in the Macs System Prefences too.
In the original software that comes with firestudio I'm getting a mic reading.. In audacity I can't get anything.
I downloaded some other software and I can get a reading (and record sound) from the mic. However I want to use Audacity for all the settings i can use for better quality!
Any idea how to get this working?
-Derek
Prosonus Firestudio Not reading input
bobdole12340
Re: Prosonus Firestudio Not reading input
<<<Any idea how to get this working?>>>
I do, or as least I have a good start. Stop using Audacity 1.2. Audacity 1.2 is not supported on newer Macs.
http://audacityteam.org/download/beta_mac
You can install both versions on your Mac if you want, but only use one at a time. Audacity 1.3 projects will not open in 1.2.
bobdole12340
Precisely the problem!
Thanks so much =)
Thanks so much =)
