'Crackling' Sound when I try to record myself singing
This section is now closed
mllebelle
Post by mllebelle » Wed Aug 25, 2010 10:23 pm
Ok, so I only got Audacity because I want to record myself singing properly with backing tracks, etc.
I have a Macbook Pro, and I recorded myself singing on Audacity by importing the instrumental track, and then creating a new track and recording my voice along with it. I also put headphones in when I was recording myself singing because I heard that's the best way to get better sound.
It's all fine except when I have to sing louder and there's crackling noises. I've tried adjusting the volume but it doesn't get rid of it.
Is there a better way to record yourself singing?
Re: 'Crackling' Sound when I try to record myself singing
Post by kozikowski » Wed Aug 25, 2010 10:47 pm
Overwhelming chance the microphone or the microphone amplifier channel is overloading. That would be the microphone you didn't tell us anything about. What, exactly are you singing into?
mllebelle
Post by mllebelle » Wed Aug 25, 2010 10:55 pm
I'm not using a mic, just singing to the laptop
Post by kozikowski » Thu Aug 26, 2010 1:41 am
Very cool! I always wondered what would happen if someone did that instead of all those fancy wires.
You do have a microphone. It's a little thing behind the grill just to the left of the "fn" key if you're on a 15" MacBook Pro. So don't cover that up with your hand while you're recording.
Apple > System Preferences > Hardware > Sound > Input > Internal Microphone > Adjust that slider so your loudest note does not cause that bouncing light meter to go all the way up -- to the right.
Nobody will award that microphone any prizes, but it should be OK. I guess it is possible to overload it if you are a particularly energetic singer. Then you have no choice but to do to an external microphone.
See if the adjustment helps.
mllebelle
Post by mllebelle » Fri Aug 27, 2010 2:08 am
It worked. Thank you so so much.
Post by kozikowski » Fri Aug 27, 2010 3:13 am
If you wander around the forum, you know we put great stock in the personal experiences -- and samples -- of the posters. So, when you get a performance you're happy with, please Export as FLAC and post four or five seconds of it here. That may be all that fits.
I was going to say reduce it to mono from stereo to save space, but that's a little involved in Audacity 1.2.
You may have the only singing performance into a MacBook Pro of anybody who's posted. That makes you a celebrity.
