Ok- Downloaded HD Tracks flac. files and was able to convert them for playback on my MAC. That part was easy....when I press play, every track plays at once. Interesting, but not what I am looking for. My goal, until I set up a dedicated mac min/USB DAC into my main system is to stream them to my SQZ Box.
How do I create individual tracks with breaks so I can then create a file under Mozart.
THX--
playback/TRACK BREAKS
Re: playback/TRACK BREAKS
They're playing all at once because you have them one above the other on the timeline. You can SOLO any one of them with the buttons on the left and then just that one will play. MUTE works, too
You probably want the Time Shift tools (left and right arrow button) and shift track two to the right so it starts after track one. Shift all the others as needed.
Then, when you export, Audacity should mix everything down to one stereo track with the songs one after the other.
Thanks for the response. i'll work with the program and follow your lead...
If I have trouble. i'll come back to you.
