1.2.5 crashes on recording (OSX 10.4.5)
This section is now closed
radioelasais
Post by radioelasais » Sun Mar 02, 2008 8:21 am
Ciao
I am new to the board and to audacity. I have a macbookpro/intel and I just installed version 1.2.5 and I am trying to learn how to use audacity. But, herr... it crashes as I hit the record button. In my prefs I set:
-built-in mic and line in but it crashes anyway
-mono
-48kHz sample rate/24bit
-aiff 16bit
No applications are running, just audacity.
Thanks for the help
Gianluca
Re: 1.2.5 crashes on recording (OSX 10.4.5)
Post by steve » Sun Mar 02, 2008 3:18 pm
Try using 48000 / 16 bit
A lot of people with Macs seem to have problems with 24 bit and reducing it to 16 bit will have very little effect on the final quality of your recordings.
radioelasais
Post by radioelasais » Sun Mar 02, 2008 4:25 pm
Now, it's working. 48kHz/32bit. Thanks. It seems 24bits recording drives my macbook pro to crash no matter what sampling freq I am using.
I am recording a radio streaming via soundflowerbed (directly onto audacity) and every now and then I get clicks and pops. Do you think its the streaming or should I look at audacity/soundbedflower?
Gianluca
Post by steve » Sun Mar 02, 2008 5:42 pm
Using 32 bit will create twice as much data as 16 bit. It could be that your hard drive is struggling to keep up. Try 16 bit and see if that's any better.
