Extract beats/shakers from songs
This section is now closed
desibeat
Post by desibeat » Mon Jun 07, 2010 4:13 pm
Hello,
I a m a newbie to Audacity.
Is it possible in Audacity to extract certain beats/shakers/hi-hat loops from original songs ?
Thanks
desibeat
Re: Extract beats/shakers from songs
Post by steve » Mon Jun 07, 2010 5:21 pm
I very much doubt that it will be possible without causing considerable detriment to the sound quality of the remaining audio.
desibeat
Post by desibeat » Tue Jun 08, 2010 3:51 am
So can it be done ? I would like to try it out. Appreciate if you can send some tips if you know how to do it.
Thanks
desibeat
Post by steve » Tue Jun 08, 2010 6:52 am
There is a VST plug-in (I think it is available for Windows only) called ExtraBoy that claims to be able to do this sort of thing http://www.elevayta.net/product13.htm
ExtraBoy is a commercial product, but if you have a Windows machine available to use there is a 14 day demo available that you could try. If you are able to try it, I'd be very interested to hear how you get on.
