no installation on mac OSX
my operating sistem is 10.4.11.
I put the audacity 1.2.6 folder into my application folder. when I lunch the program the window about languages appears and when I click on "Italian" the program collapse and the mac's report appear.
I recently re-install the opereting sistem, befor do this audacity works correctly.
Re: no installation on mac OSX
Hi
I have exactly the same problem, when I choose Swedish, the program colapses and I get the "send a raport" window, and there I read the following information:
Command: Audacity
Path: /Applications/Audicity/Audacity.app/Contents/MacOS/Audacity
Parent: WindowServer [65]
Version: 1.2.6 (1.2.6)
PID: 507
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Thread 0 Crashed:
0 net.sourceforge.audacity 0x0021fb04 0x1000 + 2222852
1 net.sourceforge.audacity 0x002204dc 0x1000 + 2225372
2 net.sourceforge.audacity 0x002220c0 0x1000 + 2232512
3 net.sourceforge.audacity 0x0000ea8c 0x1000 + 55948
4 net.sourceforge.audacity 0x00265640 0x1000 + 2508352
5 net.sourceforge.audacity 0x00006850 0x1000 + 22608
6 net.sourceforge.audacity 0x000066d0 0x1000 + 22224
and some more, that for me is like chinese, is there anyone who can help?
Thanks - robertfo
Command: Audacity
PID: 507
Thread: 0
Thread 0 Crashed:
Thanks - robertfo
Same message... you are the first to answer to this topic and unitl now I didn't received an help, sorry
Hi!
If you and me have the same problem it does not seem to be such an extrange problem, I looked att all the bugs for the program, but there was no description of such a problem. I had Audacity installed before without any problem, but I wanted to try other music programs and I desinstalled Audacity.
Have you had Audacity installed before? That could mean that something remains from the old installation that is interfering with the new installation. Such problem is common on PC systems, but it is the first time I have it on a Mac.
Best regards - robertfo
.. same collaps after starting 1.2.6 ppc version and choosing German on my Powerbook G4 with OS X.4.11.
Anyone who could help us? Thanks uti
Maybe the appended apple failure report might be helpful:
Date/Time: 2008-02-27 17:44:18.387 +0100
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: Audacity
Path: /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Parent: WindowServer [54]
PID: 889
Thread: 0
Thread 0 Crashed:
Thread 1:
0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90bf73f4 TSWaitOnSemaphoreCommon + 176
3 ...ple.CoreServices.CarbonCore 0x90bff390 TimerThread + 60
4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 0 crashed with PPC Thread State 64:
srr0: 0x000000000021fb04 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
cr: 0x24004442 xer: 0x0000000000000004 lr: 0x000000000021fb00 ctr: 0x0000000000000004
r0: 0x000000000021fb00 r1: 0x00000000bffff8f0 r2: 0x0000000000000000 r3: 0x00000000bffff940
r4: 0x00000000ffffffff r5: 0x00000000ffffffff r6: 0x00000000ffffffff r7: 0x00000000a0000000
r8: 0x00000000005a0868 r9: 0x00000000000002e8 r10: 0x0000000000000048 r11: 0x0000000000000004
r12: 0x0000000090003168 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x000000000038e0a8 r17: 0x000000000039e0a8 r18: 0x00000000bffffba0 r19: 0x00000000005ae0a8
r20: 0x00000000005ae0a8 r21: 0x00000000005ae0a8 r22: 0x0000000001322ef0 r23: 0x0000000001321e98
r24: 0x0000000001355b04 r25: 0x00000000bffff940 r26: 0x00000000003a2088 r27: 0x0000000000000001
r28: 0x00000000ffffffff r29: 0x00000000bffffa00 r30: 0x0000000000000001 r31: 0x000000000021fa88
Model: PowerBook5,6, BootROM 4.9.1f3, 1 processors, PowerPC G4 (1.5), 1.67 GHz, 512 MB
Graphics: ATI Mobility Radeon 9700, ATY,RV360M11, AGP, 64 MB
Memory Module: SODIMM1/J25UPPER, 512 MB, DDR SDRAM, PC2700U-25330
AirPort: AirPort Extreme, 405.1 (3.90.34.0.p18)
Modem: Jump, V.92, Version 1.0
Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 7 incoming serial ports
Network Service: kabel2, Ethernet, en0
PCI Card: TXN,PCIXXXX-00, cardbus, PC Card
Parallel ATA Device: MATSHITADVD-R UJ-845E
Parallel ATA Device: Hitachi HTS541080G9AT00, 74.53 GB
USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Apple Internal Keyboard/Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
USB Device: USB camera, Up to 12 Mb/sec, 500 mA
USB Device: Microsoft(R) Compact Optical Mouse, Microsoft, Up to 1.5 Mb/sec, 500 mA
Report Version: 4
Command: Audacity
PID: 889
Thread: 0
Thread 0 Crashed:
Thread 1:
I had Audacity installed, than I had to reinstal all the operating system and after this the problem cames out.robertfo wrote:If you and me have the same problem it does not seem to be such an extrange problem, I looked att all the bugs for the program, but there was no description of such a problem. I had Audacity installed before without any problem, but I wanted to try other music programs and I desinstalled Audacity.
I found the solution to (anyway my) the problem!
I found it on: http://audacityteam.org/wiki/index.php? ... in_English
On " 1.2.6 PPC only launches in English" they offer another version that I started in english, it worked!! later in PREFERENCES I changed to Swedish, and it works!
Thanks to all that have thought about the problem and I hope this will help my italian and german brothers in distress.
Hear from you if it works for you too.
robertfo
robertfo
Thanx, I also got a running application when I selected English as language. But later changes to German generated a brake-down at each next start. After deleting the 'audacity Preferences' file a new start with english was possible and for this I will continue only with English
Not if you download the program above, is (I think) a version specially PPC users that have another language than english, try it!
robertfo
robertfo
OK, it works on my G4 PPC and - also in German. Thank you!robertfo wrote:Not if you download the program above, is (I think) a version specially PPC users that have another language than english, try it!
robertfo
