how can I do these exercises?
This section is now closed
lollosa85
Post by lollosa85 » Wed Mar 31, 2010 11:30 am
Visualizza caratteri romani
hello need help! how can I do these exercises? please spiegatemelo with examples, images, in a clear and simple, I do not understand how to do .. I read the guides and tutorials but I did not understand
1) Making a harmonic complex sound (220 Hz fundamental) is simply the first 3 odd partial amplitudes with decreasing.
2) Make a chromatic scale of 5 notes from LA = 220 Hz (total duration 9 sec.)
3) Make two sinusoids in the first octave is more serious and stronger in the second.
tnx
Re: how can I do these exercises?
Post by steve » Wed Mar 31, 2010 7:39 pm
Visualizza caratteri romani = View Roman characters :?
What's this about? Are you asking us to do your homework for you?
lollosa85
Post by lollosa85 » Wed Mar 31, 2010 9:58 pm
excuse me .. I'm Italian and the forum is in English, use a translator online and I copied a line more .. but I always try to help
lollosa85
Post by lollosa85 » Wed Mar 31, 2010 10:01 pm
Seeking help because I do not know these exercises and try to use the program guide or an explanation for them to do .. the forums also serve this right?
Irish
Forum Crew
Post by Irish » Thu Apr 01, 2010 12:16 am
Io parlo un poco Italiano, e si scrivi in Italiano semplice, forse posso aiutare.
Che cosa vuoli fare con Audacity?
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Post by steve » Thu Apr 01, 2010 12:22 am
lollosa85 wrote:use a translator online and I copied a line more
Ah, that explains it :D
Happy to help, but there are many ways to approach this problem.
I don't know what your objective is, so it's difficult to know which way is best for you.
You want to write code to do this?
You want to do this one step at a time by hand using Audacity?
lollosa85 wrote:1) Making a harmonic complex sound (220 Hz fundamental) is simply the first 3 odd partial amplitudes with decreasing.
You want 220Hz + 660Hz + 1100Hz ?
You can make 3 tracks, and use the "Generate > Tone" to create the three tones.
Then use "Quick Mix" to add these tones together.
Is this the kind of answer?
Irish wrote:Io parlo un poco Italiano, e si scrivi in Italiano semplice, forse posso aiutare.
Que cosa vuoli fare con Audacity?
PO'L
Hi Irish, perhaps I should leave this to you - It'd be fairly simple to do this using Nyquist, but I'm not sure if that's what lollosa is after, or whether he wants a step-by-step method just using the standard Audacity functions. Steve.
Irish
Forum Crew
Post by Irish » Thu Apr 01, 2010 12:36 am
I'll see what I can do. At least I should be able to translate questions (and maybe answers?- my Italian is pretty basic)
PO'L
lollosa85
Post by lollosa85 » Thu Apr 01, 2010 9:24 am
scusatemi per gli errori in inglese! ma è colpa del traduttore!
io ho bisogno di capire e fare passo passo questi 3 esercizi , sto imparando ad usare audacity da poco
grazie per l'aiuto!
Realizzare un suono complesso armonico (fondamentale 220 Hz) costituito solo dalle prime 3
parziali dispari con ampiezze decrescenti.
Realizzare una scala cromatica di 5 suoni a partire dal LA=220 Hz (durata totale 9 sec.)
Realizzare due sinusoidi di cui la prima è un’ottava più grave e più forte della seconda.
grazie per la pazienza
Post by steve » Thu Apr 01, 2010 1:01 pm
Upgrade to Audacity 1.3 - it is much easier to do these things on Audacity 1.3. On Audacity 1.2 it is difficult.
Task 1 Using Audacity 1.3.11:
Open Audacity
Generate menu > Tone
Frequency= 220 Hz
Amplitude = 0.6
Click "OK" button
Tracks menu > Add New > Audio Track
Frequency= 660 Hz
Amplitude = 0.4
Click "OK" button
Frequency= 1100 Hz
Amplitude = 0.2
Click "OK" button
Ctrl+A (select All)
Tracks menu > Mix and Render
Do you understand? Is this what you want?
Irish
Forum Crew
Post by Irish » Thu Apr 01, 2010 1:57 pm
@Steve; Yes, he wants step by step instructions to perform the three tasks.
The automated translation is not great; it should read;
1) Make a harmonic complex sound (220 Hz fundamental) consisting only of the first 3 odd partials with decreasing amplitudes .
2) Make a chromatic scale of 5 notes from A = 220 Hz (total duration 9 sec.)
3) Make two sinusoids of which the first is an octave lower and louder than the second. (this isn't completely clear to me; it could be interpreted that the first should be "an octave louder" ?twice the amplitude?)
I have to leave this here. I'll come back later.
@lollosa85; Puoi capire i istruzioni in Inglese?
PO'L
