hangs up, repeats
hangs up, repeats
In the middle of recording from a tape player into audacity, hangs up and repeats the same syllable over and over, even after closing audacity and starting a new file, and after deleting audacity from computer and downloading and installing new copy. Can't tell if it's an audacity problem or computer problem or both. It had been working fine for a long time. ( iMac running 10.4.11)
Re: hangs up, repeats
Which version of Audacity? (Help menu > About Audacity)
http://forum.audacityteam.org/viewtopic ... 17&t=21921
Reinstalling Audacity rarely makes any difference unless you delete the Audacity Preferences which are saved in ~/Library/Preferences/audacity Preferenceswackerman wrote:and after deleting audacity from computer and downloading and installing new copy.
Until one of the Mac people drop by;
Do you know if your Mac is intel or PPC?
http://audacityteam.org/download/mac
Apple > About This Mac > Processor and Version.
