LameLib
Re: LameLib
You're a Linux jockey and you want me to explain executable code to you?
What's wrong with this picture?
terwilligerjones
Re: LameLib
<Looks suitably ashamed, and retires to the server room to iron his fingers to remind poor Terwilliger of his place>
Quite.
terwilliger
Quite.
terwilliger
Re: LameLib
Yes, well, before you leave, if you had to design code that would do that, how would you do it?
I personally consider it a bug, by the way. I'm sure some programmer stayed up nights making it do that, but it's been burning people right and left ever since. Final Cut video editing software has some of the same problems. If you import an MP3 audio file into Final Cut, it will seem to work. Weeks later, when you go to export your finished show to videotape or other product, it turns into a great steaming pile of garbage and it will stay that way until you remove the MP3 file.
If it's not going to work with unconditional stability, make it stop. Half-way measures suck to use a programming term.
Re: LameLib
I am a new Audacity user and was also having difficulties with the LameLib. I am on an Intel MacBook Pro running the latest version of Leopard, 10.5.3. While trying to build libmp3lame.dylib, I would get an error message: unable to write to en.lproj. I eventually scrolled through the libmp3lame-osx-universal-3.97 folder and there I found libmp3lame.dylib buried in the package/usr/local/lib directory. After moving this to the Audacity folder, I was able to export mp3 files to iTunes with no problem.
I hope this helps some the Leopard users.
Ed
Ed
Re: LameLib
I've just run into the issue for the first time. I'm not familiar with this language. Lame lib is what?...I need step by step directions as to how export the file to get a mp3 eventually...please help...
Re: LameLib
<<<I've just run into the issue for the first time. >>>
You need to produce an MP3 music file from your Audacity show?
If you Export your show to MP3 [File > Export to MP3] does the program tell you to find the lame file?
Let's get you that far first.
iancjvoice
Re: LameLib
Hello, just started using Audacity 1.2.6 on my OSX 10.4.11 and I'm trying to export files as MP3.
Audacity asks me to find LameLib. I find it, but when I try to open it I get this error message:
The encoder could not be opened.
I tried renaming the file to LameLib after I downloaded it, and it got me that far.
Without renaming the file, my Mac wouldn't recognize it as a file to open.
that's all, thanks for your help.
Re: LameLib
What kind of Mac? Apple > About This Mac. Read us what's there.
iancjvoice
Re: LameLib
Mac OSX 10.4.11
Processor: 1.5. GHz PowerPC G4, 2 MB L3 cache
Memory: 1.5. GB SDRAM
billw58
Re: LameLib
I think you may have the wrong LameLib.iancjvoice wrote: I tried renaming the file to LameLib after I downloaded it
Go to this page: http://lame.buanzo.com.ar/
You will see:
For Audacity 1.2.6 on Mac OS X (PPC):
LameLib-Carbon.sit <<--- this is the one you want.
The .sit file should unzip when you double-click it, or you may need Stuffit Expander. When you unstuff it you will get a file named "LameLib". Drag that file to your Applications folder. Now launch Audacity, go to Preferences > File Formats click on the Find Library button, etc.
-- Bill
