USB Microphone
This section is now closed
graemetw
USB Microphone
Post by graemetw » Tue Oct 13, 2009 9:13 pm
Hi
Please tell me how to get feed from a USB microphone. My only input options from Audacity are Built-in Microphone and from Built-in Input. But when I plug in a USB Mic, and switch to it in my System Preferences, Audacity does not register the mic at all.
Appreciate any help.
Love the product, but I need a better Mic, and MacBook Pro's don't support In Line Mics.
Cheers
Graeme
Re: USB Microphone
Post by kozikowski » Tue Oct 13, 2009 9:49 pm
Close everything.
Plug in the microphone.
Apple > System Preferences > Hardware > Audio > Input. Select the microphone and make sure the sound level meter bounces when you talk.
Close the panel.
Launch Audacity and...
Audacity > Preferences > Audio I/O and another panel I forgot. Set for 44100, 16-bit, Mono. [OK]
I'm using Audacity 1.3 because Intel Macs with Leopard or Snow Leopard do not support Audacity 1.2. That's important.
You can get a well behaved Audacity 1.3.7 from here...
Audacity 1.3.7 -- Mac
http://audacity.googlecode.com/files/au ... -1.3.7.zip
... or go up to the download site and get the current 1.3.
