LADSPA plug-ins installer Doesnt work
This section is now closed
adamoadam
Post by adamoadam » Tue Oct 13, 2009 12:38 am
the LADSPA plug-ins installer does not work. I installed it several times and the plug-ins don't show up!
jademan
Forum Crew
Re: LADSPA plug-ins installer Doesnt work
Post by jademan » Thu Oct 22, 2009 2:35 am
adamoadam wrote:the LADSPA plug-ins installer does not work. I installed it several times and the plug-ins don't show up!
adamoadam,
I don't have a Mac, but I understand that the 1.3.9 beta does a much better job with plug-ins than the 1.2 version. You can download the Mac beta from here.
I hope this helps.
Post by Gale Andrews » Sun Oct 25, 2009 3:04 am
You do have to restart Audacity for newly added plug-ins to show up in the Audacity menus. In 1.3.9, VST plug-ins also require a re-scan to be specified in Preferences, which then takes place when you restart.
