In and Out edit points
Isn't Audacity 1.37 supposed to have in and out edit points. For the life of me I can't figure out how to do it. Any help would be appreciated. Thanks!
Re: In and Out edit points
Where did you hear that? "I" and "O" keys are a feature request, Yes. Still pending.
The closest Audacity gets is the Label Apple-B which then becomes sticky or magnetic allowing you to select a specific segment of your performance with your mouse.
http://forum.audacityteam.org/viewtopic ... 20&t=11268
Read down a ways.
Read down a ways.
Thanks for you response. I read about the in and out edit points in a CNet review of the product. It said that Ver. 3 had the feature in it.
Wynn
Wynn
The link for that review is....
Version 3 or version 1.3? There is a quirk when you download Audacity that makes you think you should be buying AVS Editor instead. That may be at version 3...
