Source of recording device not recognized
This section is now closed
woodytel09
Post by woodytel09 » Sat Jul 11, 2009 3:54 am
Hi - I've just purchased an AKAI belt-drive turntable with USB; after downloading Audacity 1.2.5 for my iMac OSX (v10.5.7 2.66GHz Intel Core 2 Duo) I went to Preferences/Recording/Device which only allowed either "Built-in Input", or "Built-in Microphone", despite the AKAI Instruction Manual asking me to select "USB Audio CODEC". Is there some patch to fix this? Any assistance would be greatly appreciated, thanks, Terry Woodhouse (Australia)
woodytel09
Re: Source of recording device not recognized
Post by woodytel09 » Sat Jul 11, 2009 5:10 am
I've switched the USB plug to Slot2 & changed the Mac/Hardware/Sound/Preferences for Sound Input to USB Audio Codec, but still no sound out of Mac speakers while playing a record on the AKAI turntable.
Post by kozikowski » Sat Jul 11, 2009 5:14 am
Our first problem is Audacity 1.2 no longer supports modern Macs. The combination of Mac/Intel/Leopard pretty much killed off 1.2.5. It was a nice run.
So when you remove Audacity 1.2.5, be sure to trash the preference files so as not to have cross contamination.
Trash Mac Audacity Preferences
http://audacityteam.org/forum/viewtopic ... =10#p34670
After it's all gone, download Audacity 1.3.7 and install that. It should ask you "English?" at first birthday.
Close Audacity and restart the Mac with the turntable turned on and connected. See if the Turntable chipset doesn't turn up in Apple > System Preferences > Hardware > Sound > Input. Select it and the panel sound meter should jump when you play something.
Let's get it that far.
woodytel09
Re: all systems go, so far
Post by woodytel09 » Sat Jul 11, 2009 6:59 am
Hi again - thanks for the advice. I removed all trace of Audacity 1.2.x, & downloaded & installed 1.3.7, closed Audacity,
& restarted the Mac with the turntable running (the turntable chipset didn't turn up, tho). The panel sound meter showed
there was sound input, & as a consequence there was sound coming thru the Mac speakers!
So now all I have to do is familiarize myself with this Audacity software - there was a disk came with the turntable with a
thing on it called "Soundsoap SE" (from Bias software), so should be useful.
I'm a recent Mac convert from Windows PC (after 20 years) so am only gradually getting used to Mac idiosyncracies.
Thanks again for your help
Post by kozikowski » Sat Jul 11, 2009 7:18 am
Don't install the SoundSoap. Audacity 1.2 may have needed that because its noise removal was pretty dreadful, but the noise removal in 1.3 is quite good. We have one poster complaining about SoundSoap license nagging.
<<<I'm a recent Mac convert from Windows PC >>>
Welcome to the light side. Do you speak UNIX/LINUX? There's a very serviceable LINUX distribution running behind all the warm/fuzzy. There are Systems Administrators at work that do all their Mac machine management on the command line. Remember the command line....?
Last login: Fri Jul 10 19:07:03 on console
Welcome to Darwin!
jimmy:~ koz$ ls -al
total 64
drwxr-xr-x 21 koz koz 714 Jul 10 19:07 .
drwxrwxr-t 6 root admin 204 Mar 24 2007 ..
-rw-r--r-- 1 koz koz 3 Nov 3 2006 .CFUserTextEncoding
-rw-r--r-- 1 koz koz 12292 Jul 10 20:32 .DS_Store
drwx------ 2 koz koz 68 Jul 10 22:38 .Trash
-rw------- 1 koz koz 3407 Jul 1 08:56 .bash_history
