Changing Input Source
This section is now closed
nabes
Post by nabes » Sun Jun 21, 2009 4:46 pm
This may be a stupid question, but how do I change the mic source from the little built-in one on my Mac to a separate USB microphone? I plugged it in but the pulldown menu for source still just says Default Input Source as the only option. Thanks for any help!
Re: Changing Input Source
Post by kozikowski » Sun Jun 21, 2009 5:12 pm
How did you do that? I always spell "separate" wrong when I type it.
Anyway, you need to tell your Mac what you did. Apple > System Preferences > Hardware > Sound > Input.
You may need to change Audacity Preferences, too.
USB Microphone
http://kozco.com/tech/audacity/USB_Microphone.html
That's the straight-line path. Default Input Device can stay where it is.
There's a more complex but comprehensive path available in Go > Utilities > Audio Midi Setup. This is a supervisiry panel and will change the System Preferences for you -- but it's a bit harder to understand.
nabes
Post by nabes » Tue Jun 23, 2009 4:33 pm
Thanks so much, worked like a charm!
