hello everyone
i'm using 1.2.6. i used to be able to export clips (save selection as...) shorter than 5 seconds, but now, it automatically 'rounds up' so that each clip is 80 kb and 5 seconds long. i need perfectly trimmed sound bytes for a flash project i'm working on, and I just can't figure it out. help!!!
thanks,
michael
HELP! Can't export clips shorter than 5 seconds
Re: HELP! Can't export clips shorter than 5 seconds
It might do that if you have "Snap To" selected in the lower part of the Audacity operating window.
