Hello Koz
I am afraid that your suggestion did not solve the problem or I did something wrong.
Kind regards
Erik
Can't access effects - all grey - even with audio selected
Erik Olsen
Re: Can't access effects - all grey - even with audio select
Effects (and many other menu items) are only available when you are in "Stop" mode. "Pause" is not the same as "Stop". You cannot apply effects (they are greyed out) while Audacity is playing, recording or paused.
Erik Olsen
Hello Koz
thank you so much.It worked.And thank for your patience with me.
Kind regards
Erik Olsen
Kind regards
Erik Olsen
