Help with mic
Help with mic
Hey guys i just recently downloaded Audacity, it looks like a great program but my problem is i have a microphone headset that i wish to use but how to i enable it? then drop down menu in audacity is grey so i cant click it to enable it or whatever? Any help on this is great thanks in advance.
Re: Help with mic
If you are using Vista, you will probably need to enable it in the Vista Control Panel
http://audacityteam.org/wiki/index.php? ... ng_devices
Re: Help with mic
hey i did that but what do i need to be able to do to enable it in audacity? the little drop down box is grey so i cant click it..?
also do i need to set a button to press for the mic to work and record sound? if so how to i go about doing this? thanks in advance
Re: Help with mic
Edit menu > Preferences > Audio I/O tab
Select the headset as the recording and playback device.
Is it a USB headset?
If so, ensure that the headset is connected and recognised by Windows before you open Audacity.
Re: Help with mic
Hey, I just downloded and opened Audacity on my WIN XP Pro. Also my drop down menu in audacity is grey so i cant click it to enable input devices. I set preferences Audio I/O as Realtek HD Audio output and Input. Channels 2(stereo). I tryed many times, also shuting off & on my PC. The drop down menu in audacity is always grey. Do you have any suggestion ?
Re: Help with mic
Use the Windows Mixer, or the Realtek control panel to select the input rather than Audacity.
