I need help recording with Traktor Duo.
hazey412
Post by hazey412 » Mon May 04, 2009 11:22 pm
I have been messin around through the instructions and found what I thought was the right way to set up audacity to record through Traktor Scratch Duo. I have the audio I/O set to my audio4 line through USB, but it is only recording the timecode sound, not the music. Please tell me there is a way to set it to record
jonesz
Re: I need help recording with Traktor Duo.
Post by jonesz » Fri Oct 23, 2009 12:04 am
I'm having the same problem, did you figure out how to fix it?
i was thinking maybe you just need to hook up another sound card through the record channels in the mixer.
but im wondering if there's a way to do it without 2 sound cards.
if you found out let me know pal.
-jonesz
