Hi All, I'm a newbie so forgive me but I have loaded audacity onto my PC which runs Winows XP ( ihave a fission USB turntable).
After loading i get the following message when trying to record:
Error while opening sound device.Please check the input device settings and the project sample rate.
Can anyone help me to be able to record my old vinyl??
Thnaks in advance.
HELP!!! - Error while opening sound device
- Quality Assurance
Re: HELP!!! - Error while opening sound device
Read this page carefully especially the setup instructions in Section 3:OzTef wrote:Hi All, I'm a newbie so forgive me but I have loaded audacity onto my PC which runs Winows XP ( ihave a fission USB turntable).After loading i get the following message when trying to record:
http://audacityteam.org/wiki/index.php? ... turntables
Please note this particular Forum is ONLY for problems about downloading or obtaining Audacity Stable, or about it failing to complete installation. You have successfully installed Audacity. If you need more help please post a question to the Forum for your operating system and version of Audacity.
Thanks so much for your prompt & sageadvice Gale. The manufacturer's instructions didn't provide the advice you did. I'm now up & running. Yay!!!Thanks for your time (& apologies for any transgression of forum decorum)!
